How can i increase the amount of traces for assist?
Hi everyone,
i’m using more and more the voice assistant and the amount of stored traces is just too low.
Is it possible to increase this somewhere? (the traces seeing in “Debug assistant”)
In automation i can add a configuration line. But here i couldn’t find a setting.
Cheers,
Mika
Are you looking at the raw debug log? There’s quite a lot of detail there.
stage: done
run:
  pipeline: 01h0amejr3nf5059gavrx5jm7g
  language: en
  conversation_id: 01KC9G3W0P3GB0TX40AKCAKY6G
  runner_data:
    stt_binary_handler_id: null
    timeout: 300
events:
  - type: run-start
      language: en
      runner_data:
        timeout: 300
    timestamp: "2025-12-12T14:40:52.764799+00:00"
  - type: intent-start
      engine: conversation.home_assistant
      language: en
      intent_input: Getting rid of small
      device_id: null
      satellite_id: null
      prefer_local_intents: true
    timestamp: "2025-12-12T14:40:52.764830+00:00"
  - type: intent-end
      processed_locally: true
      intent_output:
        response:
          speech:
            plain:
              speech: No area named small
              extra_data: null
          card: {}
          language: en
          response_type: error
            code: no_valid_targets
        continue_conversation: false
    timestamp: "2025-12-12T14:40:52.849529+00:00"
  - type: run-end
    data: null
    timestamp: "2025-12-12T14:40:52.849579+00:00"
started: 2025-12-12T14:40:52.764Z
intent:
  language: en
  device_id: null
  satellite_id: null
  done: true
  intent_output:
    response:
      speech:
        plain:
          extra_data: null
      card: {}
      language: en
finished: 2025-12-12T14:40:52.849Z
Hi Jack,
what i’ve meant is that i need more number of stored log instances.
The individual logs are fine. I just need more of them.
Example: i’ve triggered 100 times my Voice Assistant the past week. I would like to see 20-30 past log instances (from 100).
Cheers,
Mika
I support @Hell255 's question. Sometimes the question is not correctly understood by assistant. It would be nice to have more logs stored to understand what exactly was misunderstood allowing us to define more aliases.
I understand that and…
Just ask again.
Literally this is what I do. I don’t care what in the log until I go to troubleshoot and step 1 is recreate the issue… Issue the command I’m troubleshooting and boom there’s the trace. Most helpful because I restart core a LOT as I develop Friday. And the voice log doesn’t survive a restart. Soooo I just started repro first as my normal procedure and never cared how long the log was.
Really it holds up to 100? (I’ve never checked)
Ok, so it seems this feature is clearly missing in home assistant. It would help improve (also in your case Nathan) debugging.
e.g. in all other automations we can add some yaml code to increase the amounts of traces.
Where can i add this feature request? :thinking:
