Hello All,
So I have a USB RTL-SDR stick connected to my Proxmox hypervisor and forward that USB to my Home Assistant VM. All was working well for about 2 weeks then I started getting an error in the log as follows:
Failed to submit transfer 0
Please increase your allowed usbfs buffer size with the following command:
echo 0 > /sys/module/usbcore/parameters/usbfs_memory_mb
I have the Terminal Add-On installed however when i enter the above command it get:
bash: /sys/module/usbcore/parameters/usbfs_memory_mb: Read-only file system
Any suggestions?
mterry63
(Martin)
August 2, 2024, 4:54pm
2
In Proxmox go to your Home Assistant VM and open Console. At the ha prompt enter login and try your command there.
Since you’re on Proxmox the Terminal Add-on has little value as it has a built-in terminal option.
That’s what I tired originally but the Proxmox console for the VM is the Home Assistant CLI. When I try entering the command there all I get is:
FATA[0000] Error while executing rootCmd: unknown command “echo” for “ha”
I’m having the same issue, but I’m running HAOS directly on a NUC. I’ve set up ssh access to the host like described here: Debugging the Home Assistant Operating System | Home Assistant Developer Docs
If I try to change the usbfs_memory_mb file, I get the Read-only file system error.
If I try to use ‘login’, I get incorrect login.
Any suggestions on how I can change this on HAOS? Thanks!
