I am starting with HA, and I made this automation reading here and there… It works, but not the correct way, and I think it has room for improvement.
This is the automation:
alias: Subir estores cuando hace sol
description: ''
- platform: state
entity_id: weather.home
condition:
- condition: or
conditions:
- condition: sun
before: sunset
- condition: sun
after: sunrise
- condition: numeric_state
entity_id: sun.sun
attribute: elevation
above: '12'
- choose:
- conditions:
- condition: template
value_template: >-
{{ is_state('weather.home', 'sunny') or is_state('weather.home',
'partlycloudy') }}
sequence:
- service: cover.open_cover
entity_id: cover.estores
- service: notify.telegramamibumping
message: Subiendo estores
title: Hace sol en Burgos
- conditions:
value_template: >-
{{ not is_state('weather.home', 'sunny') and not
is_state('weather.home', 'partlycloudy') }}
sequence:
- service: cover.close_cover
entity_id:
- cover.estor_2
- cover.estor_3
- cover.estor_4
message: Cerrando estores
title: No hace sol en Burgos
default: []
mode: restart
What it does is:
It checks weather state.
If the sun is between sunrise and sunset, and the sun elevation is greater than 13º
Then:
If it is sunny or partly cloudy
1.1) The covers go up
1.2) Send Notification
If it is not sunny or partly cloudy
2.1) The covers go down
2.2) Send Notification
Restart mode, for evaluate the automation every weather.state change
The things I am experimenting.
Every time the weather state is evaluated I received obvious the notification, even if the state of the covers is already open, but I don’t know how to do it…
And the other thing is that maybe the weather gets updated at for example 10:00, and at that time the condition for the elevation is not true, no actions occurred, that’s correct, but if then if the elevation is true, the automation doesn’t run until the next weather state update even if one of the weather conditions (sunny or partly cloudy) went true before, I hope I explain myself clear…
You could at least, you could combine the sunset/sunrise conditions to
condition: state
entity_id: sun.sun
state: "above_horizon"
And: The action conditions are opposite to each other. You could keep the first one, but move the second one (without conditions) to the default section.
'partlycloudy') and is_state('input_boolean.interruptor_estores',
'off') }}
is_state('weather.home', 'partlycloudy') and
is_state('input_boolean.interruptor_estores', 'on') }}
Yesterday I changed the condition template adding an input to now the state of the covers, and with that not repeating the notifications every time weather change it’s state.
I thought it was working but today, the notifications was send it again…
And I think is the and/or condition. I made it now with the visual editor and I think it is working, but I would like to know how to do it with a sentence.
'off') }}
With that condition, what I want to be is that either is sunny or partly cloudy but input is on, to be false. but I test that and it gives me true, when the weather is sunny, if I change the order of the weather state, first partly cloudy, it gives me false
This is the way and/or is evaluated in Python. The first “or" condition is true (it’s sunny), the statement evaluates to true and the rest of the conditions are ignored. Try adding parentheses to group the weather conditions together.
{{ (is_state('weather.home', 'sunny') or is_state('weather.home',
'partlycloudy')) and is_state('input_boolean.interruptor_estores',
'off') }}
