I have a home weather station that will post its data to any HTTP server using GET parameters.
An example is “HTTP GET /update wind=24.9&temperature=32.7”.
I get to select the URL text to be any static string I want. In the example I used “update”. I also get to select the server so it would be cool if this server could be the HA server on port 8123.
I would like some advise on how to get this HTTP data into a Home Assistant sensor.
Who has the cleverest idea?
And yes I know I can interface to many servers on the internet to get weather data. This is not a question about that. I am looking for a clever way to translate HTTP data into HA so I do not have to use the internet.
I looked at the requirements to use RESTful sensors. I could not find any examples of sensors using the API to update home assistant. I see examples of Home Assistant using the API to interrogate sensors. Also there is an authentication requirement and specific format required of the URL.
My sensor can only publish the simple GET with parameters (shown above). I cannot change the format of the GET it uses other that the target URL.
Can anyone point me at an example of a sensor using an HTTP GET to update HA without authentication requirements?
That is the issue. It is a simple device in my home. It can generate update commands using HTTP PUT requests as shown in my OP. It cannot add any authentication headers to the command.
If anyone has any ideas please add them to this thread.
I’d roll a simple web server in Python that receives these requests then translates them into API requests. How and where that script lives is up to you: I’m running HA in a Docker container on a NAS, and I have a spare Pi on the network so a couple of opportunities there.
For the proposed “middleman” technique, where a webserver receives data from the physical sensor and passes it on to Home Assistant, what kind of sensor integration will receive the data?
What comes to mind is the MQTT Sensor integration but I’m wondering if you thought of something else.
I’d assumed just a plain sensor via the API. As an example, here’s a bash script I run on my church’s Ubiquiti US-24-250W network switch to the public IP of my HA (via a Linode reverse proxy):
That creates and updates the entity sensor.church_switch (not the actual name I use, redacted for anonymity) with a bunch of attributes every 5 minutes:
Correct me if I’m wrong but any entity created that way exists only until Home Assistant is restarted. After a restart, it’s gone until the next time (your script) creates it again during a scheduled update (5 minutes in your example).
That’s also my understanding, yes. Same as with sensors created via AppDaemon like my bin collection sensors.
Obviously, historical values are retained, so it’s only the short window after restart where there is no data. I can live with that for these examples.
If pbix accepts the idea of using a webserver as a middleman, then it can also be implemented in Node-Red and the data forwarded to Home Assistant via either MQTT or HTTP. If pbix doesn’t already use Node-Red (or MQTT), and isn’t interested in adopting it, then what you suggested, namely a simple python-based webserver plus shell script, is probably the next easiest solution.
Thanks for the discussion. I too have thought about the HTTP->MQTT bridge idea which could be implemented on something like Node RED or my router which runs OpenWRT.
But I have been thinking on the fact that what is needed is much simpler than a webserver. A wonder if a Python script running on HA could do this directly. The script would just listen on a configurable TCP port and when it gets the string it parses the parameters, updates the sensors and returns an “OK” response to the sender. Could be developed as a generic “HTTP GET/POST” integration and possibly used by others.
Having spent untold hours helping others with Home Assistant over the past 2.5 years, your requirement is the first I’ve encountered on this forum. If you want to develop and share a custom integration for it, go ahead. However, I don’t imagine there will be a significant demand for it, especially when it’s so easy to put together functional alternatives (shown above).
Honestly, the most time-consuming part of creating that flow was discovering the Node-Red Add-on maps the “HTTP In” node to port 1880 (and URLs begin with /endpoint). Once that was sorted, the remainder was trivial.
Thanks Taras and Troon for the expert advice. It helps keep me from digging in the wrong rabbit hole.
Give me some time to experiment and I will post my results.
