How can I prevent my hardware from being disconnected?
Hello everyone, I hope you can help me I have my HA installation running inside a Synology NAS in the application “Virtual Machine Manager” what happens is that sometimes it disconnects only when rebooting and at other times even without that. Is there any way to stop it from disconnecting by itself? Thanks!
Disconnects from what?
Hello @nickrout , it disconnects from my NAS as if it were not connected and I have to go back to this screen I am showing and select it again for it to reappear.
Do you mean the usb device disconnects?
@nickrout Yes. Is there a way to reconnect without me having to put it back on?
Well for a start stop rebooting!
Also ask Synology.
@nickrout When I indicate that I restart it is not my synology but Home Assistant.
You said reboot actually.
Sorry, but I use the translator to be able to speak.
Hi, I have same issue with conbee 2 stick. Did you find any solution?
What I did was connect it to the Synology directly, since it used a USB hub before.
