I’m just taking my first steps with this great home-automation frontend (and more). I’m working with mqtt sensors (from fhem). Everything what I want (till now) is shown on the state page (first line), but I can not rearrange the sensors It only depend on the name (alphabetical ordered). Is there a way to change that? I know, I can goup my sensors, but then, they disappear from this overview line.
I need to move at least the yr sensor …
You can’t rearrange these on the first line.
What you place in a group will be shown into the group and not in the first line.
What isn’t placed somewhere is by default shown into the first line.
but how can I create this circle look when I move the sensor to a group ? The display of the sensors within a group is diffent as in the first line. Is there a way ?
Make sure that up at the top you click on SEARCH TOOL and drop down the SIZE filter. Click on ICON.
Click on the image you would like to use and then click view image. Right click on the image and select copy image address.
Open up the your customize.yaml
make an entry for each sensor (entity)
sensor.my_temperature_sensor:
friendly_name: Oven Temperature # Optional
entity_picture: http://plainicon.com/dboard/userprod/2803_dd580/prod_thumb/plainicon.com-46137-256px-10b.png # Icon Address of your choosing.
You can also use icon: in place of entity_picture: but you will have to use the mdi:icons
kinda cheeky, but if you want a sensor to be first, you can put a period in front of the friendly_name. the font is small enough that i find it barely noticeable.
