How can I remove the Map panel from the frontend?
Still, it’s clumsy that to remove “map:” you must add to configuration.yaml everything from “default_config:” (except map: of course).
I would suggest that “map:” should be removed from “default_config:” and add it by default to configuration.yaml (so that the mobile app should work out of the box). This was everything should work as before and would be easier to remove map if not needed.
Second choice would be an editor for “default_config:”… ?
The same goes for “media_source:” - I thing many users does not need it.
