How can I request and import cgi data as a sensor
How can I request and retrieve CGI data from a local url and show it as a sensor in HA?
http://192.168.1.196/Dev_status.cgi?&Port=0
{"devstatus": {
"Sys_Time": 1730723351,
"Sys_Batt_V": 54.4,
"ports": [
{ "Port": 1, "Dev": "FX","Type": "120V","Inv_I": 19,"Chg_I": 0,"Buy_I": 0,"Sell_I": 19,"VAC_in": 125,"VAC_out": 124,"Batt_V": 54.4,"AC_mode": "AC USE","INV_mode": "Sell","Warn": ["none"],"Error": ["none"],"AUX": "disabled"},
{ "Port": 2, "Dev": "CC","Type": "FM80","Out_I": 53.7,"In_I": 34,"Batt_V": 54.4,"In_V": 89.0,"Out_kWh": 8.3,"Out_AH": 153,"CC_mode": "Bulk  ","Error": ["none"],"Aux_mode": "Manual","AUX": "disabled"}
@tom_l Thanks! Iā€™ve been looing at this and I cant seem to pull in the information. Iā€™m not getting any errors in HA Iā€™m probably missing something small can you see any this I may have missed?
rest:
  - scan_interval: 120
    resource: http://192.168.1.196/Dev_status.cgi?&Port=0
      - name: Watts
        value_template: "{{ value_json['Out_kWh'] }}"
        unit_of_measurement: "w"
  - platform: rest
    scan_interval: 120
You need the full json path to the data you are interested in:
rest:
      - name: Watts
        value_template: "{{ value_json.devstatus.ports[1].Out_kWh }}"
Use this tool: https://jsonpathfinder.com/ to find other data value paths. You can add as many sensors as you want to that rest integration. They will all be populated with the one call to the resource.
YOUR THE MAN!
Thank you so much!
Small suggestion, something more descriptive than this would be worthwhile, especially as you add more sensors later.
e.g.
name: <Location> <Device> Power
Also this should be a capital W
Thanks for the advice. Two more questions for you. How do I bring in more data point? I tried this and nothing. Second how do I delete the old sensors out that where created when I was doing the trial and error?
rest:
      - name: Daily KWH
        unit_of_measurement: "kWh"
      - name: Amps
        value_template: "{{ value_json.devstatus.ports[1].Sell_I }}"
        unit_of_measurement: "AAC"
      - name: Volts
        value_template: "{{ value_json.devstatus.ports[1].VAC_in }}"
        unit_of_measurement: "V"
Use that link I provided to work out the paths to the data you want. Also be careful with your units.
rest:
      - name: Daily Energy
        state_class: total_increasing
        device_class: energy
      - name: Current
        value_template: "{{ value_json.devstatus.ports[0].Sell_I }}"
        unit_of_measurement: "A"
        state_class: measurement
        device_class: current
      - name: Voltage
        value_template: "{{ value_json.devstatus.ports[0].VAC_in }}"
        device_class: voltage
State and device classes can be helpful. Particularly for energy sensors.
I think I figured out how to delete them. Settings/Entities
Awesome! I tried playing around with the link, I couldnā€™t get a grip on it, Iā€™ll try to see if there is and youtube tutorials I see it could be me a useful tools. Thanks again for your help!!
Step 3: ā€œvalue_jsonā€ not ā€œjalue_jsonā€ :roll_eyes:
Note this tool does not work well on mobile devices.
Well thatā€™s easy!!
How come ā€˜restā€™ doesnā€™t like ā€˜idā€™? Iā€™m trying to create a sensor off that data.
rest:
      - name: Solar Daily Energy
      - name: Solar Current
      - name: Solar Voltage
      - Name: Solor Producing
        lambda: return id(SolarVoltage).state * id(HouseL2Watts).state ;
        accuracy_decimals: 1
        unit_of_measurement: "W"
unique_id: SolarDailyEnergy
The ā€˜restā€™ is not liking the lambda or template. How do I build this the custom sensor?
lambda: return id(SolarVoltage).state * id(SolarCurrent).state ;
rest:
        unique_id: SolarCurrent
        unique_id: SolarVoltage
    #   - name: Solar Producing
    #     unique_id: SolarProducing
    #   - platform: template
    #     lambda: return id(SolarVoltage).state * id(SolarCurrent).state ;
    #     accuracy_decimals: 1
    #     unit_of_measurement: "W"
    #     state_class: measurement
HA does not use lambdas. It uses jinja templates.
It also has a newer integration that you should use instead of the old sensor platform:
configuration.yaml
template:
  - sensor:
         state: "{{ states('sensor.solar_voltage')|float * states('sensor.solar_current')|float }}"
         availability: "{{ has_value('sensor.solar_voltage') and has_value('sensor.solar_current') }}"
         device_class: power
Hey @tom_l,
I have another question for you. How come I canā€™t use a template sensor in HA Energy dash board? The CGI data does not give me currant watts it only give me accumulating total and thatā€™s does work right, that why we needed to make that template V*A=W. Is there something I need to do to use those sensors in the Energy Dash Board? I believe I have the state and device class correct.
rest:
  - scan_interval: 60
template:
  - sensor:
Opps. My mistake.
That is a power sensor. Not an energy sensor. The Energy dashboard only uses energy sensors. So the template should be:
template:
  - sensor:
         device_class: power
Then feed that to an integral helper to get energy.
Be careful with the method option. You need to set it correctly to minimise approximation errors. Only use trapezoidal method for smoothly changing sensor values. Otherwise use method: left.
