Hi I’m developing a custom component and I’m using HassIO.
However in order for it to be used in HA it needs to pass ‘tox’ tests.
How can I do these tests on HassIO OS?
I couldn’t see tox
in the /usr/src/homeassistant/script/ folder but I did find lazytox.py!
Is tox not supported on HassIO?
Would running HA under VENV be a better option here?
SNoof85
(Sébastien)
3
I would say, to develop, use the venv installation. More on this with the following guide : https://developers.home-assistant.io/docs/en/development_environment.html
Thanks, I’ve got another SD card so I’ll try a VENV install on Raspbian and see how it goes.
