I’m going nuts here. I have 2 lamps. when I turn off lamp A, lamp B also turns off. lamp B is being turned off via service: lamp B turned off triggered by service switch.turn_off, 4:43:59 PM - 3 minutes ago - Supervisor.
is there a log I can check to see why lamp A is triggering lamp B?
It indicates Supervisor was responsible for turning off the light. That’s a catchall for indicating that something external to Home Assistant was responsible for the action.
Are you using Node-Red to control anything?
Are they Zigbee lights and are they grouped (in Zigbee)? In other words, are they paired in hardware to operate in unison?
I don’t use node red. One is zigbee and one is tuya cloud. I’ve disabled all related automations. no helpers. checked all outside apps. configuration.yaml. nothing physical binding them together. Any other ideas?
Hi, thanks for the thoughts. There are related automations, but I’ve disabled them all with the same results. There was a related group, but I deleted it just be sure.
No. Thanks. I was hoping to figure it out via a log somehow, but I’ve just cut my losses and renamed the entities and updated all of the automations, and that seems to have solved it.
Good you got it solved!
Now, before you go… please take the time to mark the answer as solution, you do that by selecting the three dots under the post:
Then select the check box:
Don’t forget too while you’re down there to click the heart to like the post, as a way of saying thank you.
