I hacked something together - I copied the generic_thermostat component to generic_aqi_controller, and added some code to control the fan speed based on hard-coded thresholds. Seems to work alright.
I couldn’t change the units though, the ClimateEntity class can only use temperature as the unit.
Commit on GitHub: Set fan speed percentage based on some hard-coded thresholds for pm25 · ndbroadbent/home-assistant@ceeb0e4 · GitHub
Code:
"""Adds support for generic aqi controller."""
from __future__ import annotations
import asyncio
import logging
import math
from typing import Any
import voluptuous as vol
from homeassistant.components.climate import (
ATTR_PRESET_MODE,
PLATFORM_SCHEMA,
PRESET_ACTIVITY,
PRESET_AWAY,
PRESET_COMFORT,
PRESET_HOME,
PRESET_NONE,
PRESET_SLEEP,
ClimateEntity,
ClimateEntityFeature,
HVACAction,
HVACMode,
from homeassistant.const import (
ATTR_ENTITY_ID,
ATTR_TEMPERATURE,
CONF_NAME,
CONF_UNIQUE_ID,
EVENT_HOMEASSISTANT_START,
PRECISION_HALVES,
PRECISION_TENTHS,
PRECISION_WHOLE,
SERVICE_TURN_OFF,
SERVICE_TURN_ON,
STATE_ON,
STATE_UNAVAILABLE,
STATE_UNKNOWN,
from homeassistant.core import DOMAIN as HA_DOMAIN, CoreState, HomeAssistant, callback
from homeassistant.components.fan import DOMAIN as FAN_DOMAIN, SERVICE_SET_PERCENTAGE, ATTR_PERCENTAGE
from homeassistant.exceptions import ConditionError
from homeassistant.helpers import condition
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.entity_platform import AddEntitiesCallback
from homeassistant.helpers.event import (
async_track_state_change_event,
async_track_time_interval,
from homeassistant.helpers.reload import async_setup_reload_service
from homeassistant.helpers.restore_state import RestoreEntity
from homeassistant.helpers.typing import ConfigType, DiscoveryInfoType
from . import DOMAIN, PLATFORMS
_LOGGER = logging.getLogger(__name__)
DEFAULT_TOLERANCE = 0.3
DEFAULT_NAME = "Generic AQI Controller"
CONF_HEATER = "heater"
CONF_SENSOR = "target_sensor"
CONF_MIN_TEMP = "min_temp"
CONF_MAX_TEMP = "max_temp"
CONF_TARGET_TEMP = "target_temp"
# CONF_AC_MODE = "ac_mode"
CONF_MIN_DUR = "min_cycle_duration"
CONF_COLD_TOLERANCE = "cold_tolerance"
CONF_HOT_TOLERANCE = "hot_tolerance"
CONF_KEEP_ALIVE = "keep_alive"
CONF_INITIAL_HVAC_MODE = "initial_hvac_mode"
CONF_PRECISION = "precision"
CONF_TEMP_STEP = "target_temp_step"
CONF_PRESETS = {
p: f"{p}_temp"
for p in (
PRESET_AWAY,
PRESET_COMFORT,
PRESET_HOME,
PRESET_SLEEP,
PRESET_ACTIVITY,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
vol.Required(CONF_HEATER): cv.entity_id,
vol.Required(CONF_SENSOR): cv.entity_id,
# vol.Optional(CONF_AC_MODE): cv.boolean,
vol.Optional(CONF_MAX_TEMP): vol.Coerce(float),
vol.Optional(CONF_MIN_DUR): cv.positive_time_period,
vol.Optional(CONF_MIN_TEMP): vol.Coerce(float),
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Optional(CONF_COLD_TOLERANCE, default=DEFAULT_TOLERANCE): vol.Coerce(float),
vol.Optional(CONF_HOT_TOLERANCE, default=DEFAULT_TOLERANCE): vol.Coerce(float),
vol.Optional(CONF_TARGET_TEMP): vol.Coerce(float),
vol.Optional(CONF_KEEP_ALIVE): cv.positive_time_period,
vol.Optional(CONF_INITIAL_HVAC_MODE): vol.In(
[HVACMode.COOL, HVACMode.HEAT, HVACMode.OFF]
vol.Optional(CONF_PRECISION): vol.In(
[PRECISION_TENTHS, PRECISION_HALVES, PRECISION_WHOLE]
vol.Optional(CONF_TEMP_STEP): vol.In(
vol.Optional(CONF_UNIQUE_ID): cv.string,
).extend({vol.Optional(v): vol.Coerce(float) for (k, v) in CONF_PRESETS.items()})
async def async_setup_platform(
hass: HomeAssistant,
config: ConfigType,
async_add_entities: AddEntitiesCallback,
discovery_info: DiscoveryInfoType | None = None,
) -> None:
"""Set up the generic thermostat platform."""
await async_setup_reload_service(hass, DOMAIN, PLATFORMS)
name = config.get(CONF_NAME)
heater_entity_id = config.get(CONF_HEATER)
sensor_entity_id = config.get(CONF_SENSOR)
min_temp = config.get(CONF_MIN_TEMP)
max_temp = config.get(CONF_MAX_TEMP)
target_temp = config.get(CONF_TARGET_TEMP)
ac_mode = True # config.get(CONF_AC_MODE)
min_cycle_duration = config.get(CONF_MIN_DUR)
cold_tolerance = config.get(CONF_COLD_TOLERANCE)
hot_tolerance = config.get(CONF_HOT_TOLERANCE)
keep_alive = config.get(CONF_KEEP_ALIVE)
initial_hvac_mode = config.get(CONF_INITIAL_HVAC_MODE)
presets = {
key: config[value] for key, value in CONF_PRESETS.items() if value in config
precision = config.get(CONF_PRECISION)
target_temperature_step = config.get(CONF_TEMP_STEP)
unit = hass.config.units.temperature_unit
# unit = CONCENTRATION_MICROGRAMS_PER_CUBIC_METER
unique_id = config.get(CONF_UNIQUE_ID)
async_add_entities(
GenericThermostat(
name,
heater_entity_id,
sensor_entity_id,
min_temp,
max_temp,
target_temp,
ac_mode,
min_cycle_duration,
cold_tolerance,
hot_tolerance,
keep_alive,
initial_hvac_mode,
presets,
precision,
target_temperature_step,
unit,
unique_id,
class GenericThermostat(ClimateEntity, RestoreEntity):
"""Representation of a Generic Thermostat device."""
_attr_should_poll = False
def __init__(
self,
name,
heater_entity_id,
sensor_entity_id,
min_temp,
max_temp,
target_temp,
ac_mode,
min_cycle_duration,
cold_tolerance,
hot_tolerance,
keep_alive,
initial_hvac_mode,
presets,
precision,
unit,
unique_id,
"""Initialize the thermostat."""
self._attr_name = name
self.heater_entity_id = heater_entity_id
self.sensor_entity_id = sensor_entity_id
self.ac_mode = ac_mode
self.min_cycle_duration = min_cycle_duration
self._cold_tolerance = cold_tolerance
self._hot_tolerance = hot_tolerance
self._keep_alive = keep_alive
self._hvac_mode = initial_hvac_mode
self._saved_target_temp = target_temp or next(iter(presets.values()), None)
self._temp_precision = precision
self._temp_target_temperature_step = target_temperature_step
# if self.ac_mode:
self._attr_hvac_modes = [HVACMode.COOL, HVACMode.OFF]
# self._attr_hvac_modes = [HVACMode.FAN_ONLY, HVACMode.OFF]
# else:
# self._attr_hvac_modes = [HVACMode.HEAT, HVACMode.OFF]
self._active = False
self._cur_temp = None
self._temp_lock = asyncio.Lock()
self._min_temp = min_temp
self._max_temp = max_temp
self._attr_preset_mode = PRESET_NONE
self._target_temp = target_temp
self._attr_temperature_unit = unit
self._attr_unique_id = unique_id
self._attr_supported_features = ClimateEntityFeature.TARGET_TEMPERATURE
if len(presets):
self._attr_supported_features |= ClimateEntityFeature.PRESET_MODE
self._attr_preset_modes = [PRESET_NONE] + list(presets.keys())
else:
self._presets = presets
async def async_added_to_hass(self) -> None:
"""Run when entity about to be added."""
await super().async_added_to_hass()
# Add listener
self.async_on_remove(
async_track_state_change_event(
self.hass, [self.sensor_entity_id], self._async_sensor_changed
self.hass, [self.heater_entity_id], self._async_switch_changed
if self._keep_alive:
async_track_time_interval(
self.hass, self._async_control_heating, self._keep_alive
@callback
def _async_startup(*_):
"""Init on startup."""
sensor_state = self.hass.states.get(self.sensor_entity_id)
if sensor_state and sensor_state.state not in (
STATE_UNAVAILABLE,
STATE_UNKNOWN,
self._async_update_temp(sensor_state)
self.async_write_ha_state()
switch_state = self.hass.states.get(self.heater_entity_id)
if switch_state and switch_state.state not in (
STATE_UNAVAILABLE,
STATE_UNKNOWN,
self.hass.create_task(self._check_switch_initial_state())
if self.hass.state == CoreState.running:
_async_startup()
else:
self.hass.bus.async_listen_once(EVENT_HOMEASSISTANT_START, _async_startup)
# Check If we have an old state
if (old_state := await self.async_get_last_state()) is not None:
# If we have no initial temperature, restore
if self._target_temp is None:
# If we have a previously saved temperature
if old_state.attributes.get(ATTR_TEMPERATURE) is None:
if self.ac_mode:
self._target_temp = self.max_temp
else:
self._target_temp = self.min_temp
_LOGGER.warning(
"Undefined target temperature, falling back to %s",
self._target_temp,
else:
self._target_temp = float(old_state.attributes[ATTR_TEMPERATURE])
if (
self.preset_modes
and old_state.attributes.get(ATTR_PRESET_MODE) in self.preset_modes
self._attr_preset_mode = old_state.attributes.get(ATTR_PRESET_MODE)
if not self._hvac_mode and old_state.state:
self._hvac_mode = old_state.state
else:
# No previous state, try and restore defaults
if self.ac_mode:
else:
_LOGGER.warning(
"No previously saved temperature, setting to %s", self._target_temp
# Set default state to off
if not self._hvac_mode:
self._hvac_mode = HVACMode.OFF
@property
def precision(self):
"""Return the precision of the system."""
if self._temp_precision is not None:
return self._temp_precision
return super().precision
@property
def target_temperature_step(self):
"""Return the supported step of target temperature."""
if self._temp_target_temperature_step is not None:
return self._temp_target_temperature_step
# if a target_temperature_step is not defined, fallback to equal the precision
return self.precision
@property
def current_temperature(self):
"""Return the sensor temperature."""
return self._cur_temp
@property
def hvac_mode(self):
"""Return current operation."""
return self._hvac_mode
@property
def hvac_action(self):
"""Return the current running hvac operation if supported.
Need to be one of CURRENT_HVAC_*.
if self._hvac_mode == HVACMode.OFF:
return HVACAction.OFF
if not self._is_device_active:
return HVACAction.IDLE
if self.ac_mode:
return HVACAction.COOLING
return HVACAction.HEATING
@property
def target_temperature(self):
"""Return the temperature we try to reach."""
return self._target_temp
async def async_set_hvac_mode(self, hvac_mode: HVACMode) -> None:
"""Set hvac mode."""
if hvac_mode == HVACMode.HEAT:
self._hvac_mode = HVACMode.HEAT
await self._async_control_heating(force=True)
elif hvac_mode == HVACMode.COOL:
self._hvac_mode = HVACMode.COOL
elif hvac_mode == HVACMode.OFF:
if self._is_device_active:
await self._async_heater_turn_off()
else:
_LOGGER.error("Unrecognized hvac mode: %s", hvac_mode)
return
# Ensure we update the current operation after changing the mode
async def async_set_temperature(self, **kwargs: Any) -> None:
"""Set new target temperature."""
if (temperature := kwargs.get(ATTR_TEMPERATURE)) is None:
return
self._target_temp = temperature
@property
def min_temp(self):
"""Return the minimum temperature."""
if self._min_temp is not None:
return self._min_temp
# get default temp from super class
return super().min_temp
@property
def max_temp(self):
"""Return the maximum temperature."""
if self._max_temp is not None:
return self._max_temp
# Get default temp from super class
return super().max_temp
async def _async_sensor_changed(self, event):
"""Handle temperature changes."""
new_state = event.data.get("new_state")
if new_state is None or new_state.state in (STATE_UNAVAILABLE, STATE_UNKNOWN):
return
self._async_update_temp(new_state)
await self._async_control_heating()
async def _check_switch_initial_state(self):
"""Prevent the device from keep running if HVACMode.OFF."""
if self._hvac_mode == HVACMode.OFF and self._is_device_active:
_LOGGER.warning(
"The climate mode is OFF, but the switch device is ON. Turning off device %s",
self.heater_entity_id,
@callback
def _async_switch_changed(self, event):
"""Handle heater switch state changes."""
old_state = event.data.get("old_state")
if new_state is None:
return
if old_state is None:
@callback
def _async_update_temp(self, state):
"""Update thermostat with latest state from sensor."""
try:
cur_temp = float(state.state)
if math.isnan(cur_temp) or math.isinf(cur_temp):
raise ValueError(f"Sensor has illegal state {state.state}")
self._cur_temp = cur_temp
except ValueError as ex:
_LOGGER.error("Unable to update from sensor: %s", ex)
async def _async_control_heating(self, time=None, force=False):
"""Check if we need to turn heating on or off."""
async with self._temp_lock:
if not self._active and None not in (
self._cur_temp,
self._target_temp,
self._active = True
_LOGGER.info(
"Obtained current and target temperature. "
"Generic thermostat active. %s, %s",
self._cur_temp,
self._target_temp,
if not self._active or self._hvac_mode == HVACMode.OFF:
return
# If the `force` argument is True, we
# ignore `min_cycle_duration`.
# If the `time` argument is not none, we were invoked for
# keep-alive purposes, and `min_cycle_duration` is irrelevant.
if not force and time is None and self.min_cycle_duration:
current_state = STATE_ON
else:
current_state = HVACMode.OFF
try:
long_enough = condition.state(
self.hass,
current_state,
self.min_cycle_duration,
except ConditionError:
long_enough = False
if not long_enough:
return
too_cold = self._target_temp >= self._cur_temp + self._cold_tolerance
too_hot = self._cur_temp >= self._target_temp + self._hot_tolerance
if self._cur_temp > 100:
await self._async_fan_set_speed_percentage(100)
elif self._cur_temp > 50:
await self._async_fan_set_speed_percentage(66)
else:
await self._async_fan_set_speed_percentage(33)
if (self.ac_mode and too_cold) or (not self.ac_mode and too_hot):
_LOGGER.info("Turning off heater %s", self.heater_entity_id)
elif time is not None:
# The time argument is passed only in keep-alive case
_LOGGER.info(
"Keep-alive - Turning on heater heater %s",
await self._async_heater_turn_on()
else:
if (self.ac_mode and too_hot) or (not self.ac_mode and too_cold):
_LOGGER.info("Turning on heater %s", self.heater_entity_id)
_LOGGER.info(
"Keep-alive - Turning off heater %s", self.heater_entity_id
@property
def _is_device_active(self):
"""If the toggleable device is currently active."""
if not self.hass.states.get(self.heater_entity_id):
return None
return self.hass.states.is_state(self.heater_entity_id, STATE_ON)
@property
def _current_fan_percentage(self):
if not state:
return None
_LOGGER.info("Current fan percentage %d", state.attributes["percentage"])
return state.attributes["percentage"]
async def _async_heater_turn_on(self):
"""Turn heater toggleable device on."""
data = {ATTR_ENTITY_ID: self.heater_entity_id}
await self.hass.services.async_call(
HA_DOMAIN, SERVICE_TURN_ON, data, context=self._context
async def _async_heater_turn_off(self):
"""Turn heater toggleable device off."""
HA_DOMAIN, SERVICE_TURN_OFF, data, context=self._context
async def _async_fan_set_speed_percentage(self, percentage):
"""Set fan speed."""
if self._current_fan_percentage == percentage:
return
_LOGGER.info("Setting fan speed percentage to %d", percentage)
data = { ATTR_ENTITY_ID: self.heater_entity_id, ATTR_PERCENTAGE: percentage }
FAN_DOMAIN, SERVICE_SET_PERCENTAGE, data, context=self._context
async def async_set_preset_mode(self, preset_mode: str) -> None:
"""Set new preset mode."""
if preset_mode not in (self.preset_modes or []):
raise ValueError(
f"Got unsupported preset_mode {preset_mode}. Must be one of {self.preset_modes}"
if preset_mode == self._attr_preset_mode:
# I don't think we need to call async_write_ha_state if we didn't change the state
return
if preset_mode == PRESET_NONE:
self._target_temp = self._saved_target_temp
else:
if self._attr_preset_mode == PRESET_NONE:
self._saved_target_temp = self._target_temp
self._attr_preset_mode = preset_mode
self._target_temp = self._presets[preset_mode]
Diff:
diff --git a/homeassistant/components/generic_aqi_controller/climate.py b/homeassistant/components/generic_aqi_controller/climate.py
index dadfc995e0..1746970ffa 100644
--- a/homeassistant/components/generic_aqi_controller/climate.py
+++ b/homeassistant/components/generic_aqi_controller/climate.py
@@ -1,4 +1,4 @@
-"""Adds support for generic thermostat units."""
+"""Adds support for generic aqi controller."""
import asyncio
@@ -38,6 +38,8 @@ from homeassistant.const import (
STATE_UNKNOWN,
+from homeassistant.components.fan import DOMAIN as FAN_DOMAIN, SERVICE_SET_PERCENTAGE, ATTR_PERCENTAGE
@@ -55,14 +57,14 @@ from . import DOMAIN, PLATFORMS
-DEFAULT_NAME = "Generic Thermostat"
+DEFAULT_NAME = "Generic AQI Controller"
-CONF_AC_MODE = "ac_mode"
+# CONF_AC_MODE = "ac_mode"
@@ -86,7 +88,7 @@ PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
- vol.Optional(CONF_AC_MODE): cv.boolean,
+ # vol.Optional(CONF_AC_MODE): cv.boolean,
@@ -125,7 +127,7 @@ async def async_setup_platform(
- ac_mode = config.get(CONF_AC_MODE)
+ ac_mode = True # config.get(CONF_AC_MODE)
@@ -137,6 +139,7 @@ async def async_setup_platform(
+ # unit = CONCENTRATION_MICROGRAMS_PER_CUBIC_METER
async_add_entities(
@@ -202,10 +205,11 @@ class GenericThermostat(ClimateEntity, RestoreEntity):
- if self.ac_mode:
- self._attr_hvac_modes = [HVACMode.COOL, HVACMode.OFF]
- else:
- self._attr_hvac_modes = [HVACMode.HEAT, HVACMode.OFF]
+ # if self.ac_mode:
+ self._attr_hvac_modes = [HVACMode.COOL, HVACMode.OFF]
+ # self._attr_hvac_modes = [HVACMode.FAN_ONLY, HVACMode.OFF]
+ # else:
+ # self._attr_hvac_modes = [HVACMode.HEAT, HVACMode.OFF]
@@ -479,6 +483,13 @@ class GenericThermostat(ClimateEntity, RestoreEntity):
+ if self._cur_temp > 100:
+ await self._async_fan_set_speed_percentage(100)
+ elif self._cur_temp > 50:
+ await self._async_fan_set_speed_percentage(66)
+ else:
+ await self._async_fan_set_speed_percentage(33)
@@ -500,6 +511,8 @@ class GenericThermostat(ClimateEntity, RestoreEntity):
@property
@@ -508,6 +521,16 @@ class GenericThermostat(ClimateEntity, RestoreEntity):
+ @property
+ def _current_fan_percentage(self):
+ """If the toggleable device is currently active."""
+ state = self.hass.states.get(self.heater_entity_id)
+ if not state:
+ return None
+ _LOGGER.info("Current fan percentage %d", state.attributes["percentage"])
+ return state.attributes["percentage"]
@@ -522,6 +545,17 @@ class GenericThermostat(ClimateEntity, RestoreEntity):
+ async def _async_fan_set_speed_percentage(self, percentage):
+ """Set fan speed."""
+ if self._current_fan_percentage == percentage:
+ return
+ _LOGGER.info("Setting fan speed percentage to %d", percentage)
+ data = { ATTR_ENTITY_ID: self.heater_entity_id, ATTR_PERCENTAGE: percentage }
+ await self.hass.services.async_call(
+ FAN_DOMAIN, SERVICE_SET_PERCENTAGE, data, context=self._context
