don’t forget you need to restart before you’ll notice the changes
Getting
expected a dictionary for dictionary value @ data[‘customize’]
when I check it in developer tools
Entered this in configuration.yaml
homeassistant:
customize:
binary_sensor.switch.unk_manufacturer_unk_model_switch
device_class:door
binary_sensor.switch.unk_manufacturer_unk_model_switch_2
device_class:door
Can you please check you entities and check the real name?
I think it should look like:
homeassistant:
customize:
device_class:door
device_class:door
You are missing a blank space between device_class: door
When I put in a space, code studio complains about a bad indentation of a mapping entry
Could you please share again this customize part of your configuration.yaml?
Then one when code studio complains.
Sorry, my bad, that is what you get when typing on a phone
Another handycap is that the new studio code server has poor copy/paste functionality on a phone
homeassistant:
customize:
device_class: door
device_class: door
You need colons after each entity (as added above)
Thanks Chris that got rid of the errors. After a restart the entity is still a switch, with no change in being able to change it :((
As far as I know, switches doesn’t have support to device_class as a door.
You will have to create a template binary_sensor…
Use this example from the docs and with a few modifications you will be able to set a sensor for door.
http://homeassistant.local:8123/local/nspanel/dev/ns-panel.tft
Something like this:
template:
- binary_sensor:
- name: Front door
device_class: door
availability: "{{ has_value('switch.unk_manufacturer_unk_model_switch') }}"
state: "{{ states('switch.unk_manufacturer_unk_model_switch') }}"
- name: The other door
device_class: door
availability: "{{ has_value('switch.unk_manufacturer_unk_model_switch_2') }}"
state: "{{ states('switch.unk_manufacturer_unk_model_switch_2') }}"
Thanks Edward I will give that a try.
That went smooth, Now how do I use that in a dashboard? it doesn’t show up as a device or as an entity. Sorry to be a PIA.
Those are entities without a device. You can display in any lovelace dashboard or use in your automations, just look for the entity_id (binary_sensor.front_door, etc.) or the name you gave (Front door, etc), but those are not shown into your device page as they don´t belong to that device.
You can add a unique_id for those to improve a bit what you can do with those entities (like renaming, etc. with the UI), but not more than this (I’ve used the UUID generator embedded into Studio Code Server):
template:
- binary_sensor:
- name: Front door
unique_ui: cddebfc6-db20-4f75-aab3-4d5b4df1ed2f
device_class: door
unique_ui: 1ba5e6e6-45ae-4aca-8b80-a60b8cf96e26
device_class: door
Thanks Edward,
I figured it out.
Have a great weekend
