I’m comfortable showing the various temp sensors I have on a chart but now I also want to chart what the aircon set temp was at the same time… How do we gain access to the values of a climate item?
In mini-graph-card you can display graphs for entity state & entity attribute.
If “aircon set temp” is either a state or an attribute of some entity - then add it to the card by a corresponding way:
Appreciate the help guys… Must admit the hardest part was identified the exact name of the attributes but I managed to do it by adding a single Entity card where we can pick attributes and then looking at the code.
