How can I sort my motion sensors by last-changed?
I have an entities card listing my motion sensors (thanks konnected.io!) with secondary_info showing the last-changed state attribute, like so:
Is there any way to sort them, so the most recent motion one appears at the top?
Ideally I’d also like to style them a bit so any motion within say 5 minutes is bold or something. I don’t mind using custom cards.
Any suggestions?
That’s not possible with the entities card, but you can use the home-feed-card for it.
@R_J Try using this Display which motion sensor triggered alarm in UI it works well for me.
this looks like it fits the bill, thanks!
It seems pretty solid in my use so far.
I created an input_text and an automation which “feeds” it with details about the last 5 motions like this:
input_text:
  last_motions:
    max: 255
automation:
  # Monitor motion sensors
  - alias: Monitor motion sensors
    - platform: state
      entity_id:
      # motion sensors
      - binary_sensor.alarm_zone_2
      - binary_sensor.alarm_zone_3
      - binary_sensor.alarm_zone_4
      - etc
      # open-close sensors
      - binary_sensor.alarm_zone_1
      - binary_sensor.alarm_zone_5
      - binary_sensor.alarm_zone_7
      - etc
      to: 'on'
    - service: input_text.set_value
        entity_id: input_text.last_motions
        value: >-
          {% set newItem = trigger.to_state.last_changed.strftime('%H:%M:%S') + ' - ' + trigger.to_state.attributes.friendly_name %}
          {% set txt = states('input_text.last_motions') %}
          {% set strList = txt.split("|") %}
          {% set ns = namespace(newTxt=newItem) %}
          {% for item in strList %}
          {%   if loop.index < 5 %}
          {%     set ns.newTxt = ns.newTxt + "|" + item %}
          {%   endif %}
          {% endfor %}
          {{ ns.newTxt }}
At each motion event the event time and the motion sensor’s friendly name is inserted at the beginning of input_text.last_motions separated with a special character from the rest allowing to transform the string into a list of event-time - sensor-name pairs.
On the lovelace-UI the string is rendered using a markdown card like this:
- type: markdown
  title: Last five motions...
  content: "{{ states('input_text.last_motions') | replace('|', '\n') }}"
The markdown card could be combined with a conditional card which could display the markdown content only if the last_changed time of the input_text is not older than n minutes (implemented in a form of a template binary sensor).
That’s a superb solution! In case of somebody is interested in getting the timezone correct as well for the triggers (as it’s UTC otherwise), just have the newItem defined as:
newItem = trigger.to_state.last_changed.astimezone().strftime('%H:%M:%S')
Meanwhile I simplified it (I removed the for statement, using a namespace to inject a variable from the outer scope is a little bit noisy)…
@tarmo - you are right, you should convert last_changed value to local
    value: >-
      {% set newItem = as_local(trigger.to_state.last_changed).strftime('%H:%M:%S') + ' - ' + trigger.to_state.attributes.friendly_name %}
      {% set strList = txt.split("|")[:4] %}
      {% set txt = newItem + "|" + strList|join("|") %}
      {{ txt }}
