How can I split my config by Projects?
Hey
is it possible to split my config by Projects? Right now I have a full list “Sensors” “scripts” etc.
but it would be easier if I could split the whole configuration into projects.
And if so - is there any problem with multiple sensor: tags or mqtt: tags?
As an example - normally i’ve to split the Project in two settings. “mqtt” and “templates”
### openWB ######
mqtt:
    - name: grid Tages Verbrauch
      state_topic: "openWB/evu/DailyYieldImportKwh"
      unit_of_measurement: kWh
      device_class: energy
      state_class: total_increasing
      icon: mdi:transmission-tower
    - name: OpenWB daily_yield_house
      state_topic: "openWB/global/DailyYieldHausverbrauchKwh"
    - name: OpenWB EVU Watt
      state_topic: "openWB/evu/W"
    - name: OpenWB PV Watt
      state_topic: "openWB/pv/W"
    - name: OpenWB Lademodus
      state_topic: "openWB/global/ChargeMode"
    - name: OpenWB SoC LP1
      state_topic: "openWB/lp/1/%Soc"
    - name: OpenWB Loading LP1 Watt
      state_topic: "openWB/lp/1/W"
    - name: OpenWB Loaded kWh
      state_topic: "openWB/lp/1/kWhActualCharged"
    - name: Energieverbrauch
      state_topic: "openWB/global/WHouseConsumption"
template:
    sensors:
      openwb_status:
        friendly_name: "OpenWB Status"
        value_template: >-
          {% if states('sensor.openwb_lademodus') == '0' %}
            Sofort Laden
          {% elif states('sensor.openwb_lademodus') == '1' %}
            Min und PV
          {% elif states('sensor.openwb_lademodus') == '2' %}
            Nur PV
          {% elif states('sensor.openwb_lademodus') == '3' %}
            Stop
          {% elif states('sensor.openwb_lademodus') == '4' %}
            Standby
          {% else %}
            Unknown
            {% endif %}
ty <3
Perfect !
