I am looking for a way to update (or even check?) the firmware of my Conbee 2 stick. In the past I was using the deCONZ addon (Phoscon App) which has an option to update the stick but this is not available in the ZHA integration. Anyone that can help me out here?
Thank you! I am wondering if after updating the firmware of the stick my current ZHA setup keeps working? On the ZHA docu page at: https://www.home-assistant.io/integrations/zha/ I saw that they use the zigpy-deconz library (https://github.com/zigpy/zigpy-deconz), is there a risk upgrading to a firmware version not supported in any way by the library?
UPDATE: just upgraded the firmware from a version of 27 may 2019 to a version released on 10 may 2020, let’s see if this helps fix my current issue.
One thing I do see in my kernel logging is the following:
usb 1-1: reset full-speed USB device number 2 using xhci_hcd (usb 1-1 is the conbee stick) not sure if I am the only one experiencing this.
