How can i use bitcoded sensor
Hi
i have an modbus sensor:
- name: isg_betriebsstatus
input_type: input
address: 2500
slave: 1
the value of the sensor is bitcoded:
HK 1 PUMPE B0
HK 2 PUMPE B1
AUFHEIZPROGRAMM B2
NHZ STUFEN IN BETRIEB B3
WP IM HEIZBETRIEB B4
WP IM WARMWASSERBETRIEB B5
VERDICHTER IN BETRIEB B6
SOMMERBETRIEB AKTIV B7
KUEHLBETRIEB AKTIV B8
MIN. EINE IWS IM ABTAUBETRIEB B9
SILENTMODE 1 AKTIV B10
SILENTMODE 2 AKTIV (WP AUS) B11
for example i get a value of 81 = 01010001
which means bit 0 (HK 1 PUMPE ), bit 4(WP IM HEIZBETRIEB) and bit 6 (VERDICHTER IN BETRIEB ) are active
how can i show these values in homeassitant?
Welcome to HA! :slight_smile:
Take a look here:
thanks. that was the right hint. i will try that.
here my working config for the stiebel eltron heat pump. i hope it will help others.
` modbus:
  • name: “isg”
    type: tcp
    host: 192.168.1.xx
    port: 502
    sensors:
    • name: isg_aussentemperatur
      input_type: input
      address: 506
      unit_of_measurement: °C
      slave: 1
      scale: 0.1
      precision: 1
    • name: isg_ISTTEMPERATUR_HK_1
      input_type: input
      address: 507
      state_class: measurement
      slave: 1
      scale: 0.1
      precision: 1
    • name: isg_SOLLTEMPERATUR_HK_1
      input_type: input
      address: 509
      slave: 1
      scale: 0.1
      precision: 1
    • name: isg_RUECKLAUFEMPERATUR_WP_1
      input_type: input
      address: 541
      slave: 1
      scale: 0.1
      precision: 1
    • name: isg_VORLAUFTEMPERATUR_WP_1
      input_type: input
      address: 542
      slave: 1
      scale: 0.1
      precision: 1
    • name: isg_betriebsstatus
      input_type: input
      address: 2500
      slave: 1
    • name: isg_evu-sperre
      input_type: input
      address: 2501
      slave: 1
    • name: isg_PUFFERLADEPUMPE_1
      input_type: input
      address: 2511
      slave: 1
    • name: isg_VERDICHTER_1
      input_type: input
      address: 2541
      slave: 1
    • name: isg_WASSERVOLUMENSTROM_WP_1
      input_type: input
      address: 547
      unit_of_measurement: l/m
      slave: 1
      scale: 0.1
      precision: 1
    • name: isg_VD_HEIZEN_TAG
      input_type: input
      address: 3510
      unit_of_measurement: kWh
      state_class: total
      slave: 1
      scale: 1
      precision: 1
      device_class: energy
    • name: isg_VD_HEIZEN_SUMME
      input_type: input
      address: 3511
      state_class: total_increasing
      slave: 1
      scale: 1
      precision: 1
      template:
  • sensor:
    • name: “Total aktueller Stromverbrauch”
      unit_of_measurement: “Watt”
      state: >
      {{ states(“sensor.shellyem3_485519c9ac6c_channel_c_power”) | float + states(“sensor.shellyem3_485519c9ac6c_channel_b_power”)|float + states(“sensor.shellyem3_485519c9ac6c_channel_a_power”)|float}}
  • binary_sensor:
    • name: “isg_betriebsstatus_hk1_pumpe”
      state: " {{ states(‘sensor.isg_betriebsstatus’)|int|bitwise_and(1) > 0 }}"
      device_class: “running”
    • name: “isg_betriebsstatus_hk2_pumpe”
      state: " {{ states(‘sensor.isg_betriebsstatus’)|int|bitwise_and(2) > 0 }}"
    • name: “isg_betriebsstatus_aufheizprogramm”
      state: " {{ states(‘sensor.isg_betriebsstatus’)|int|bitwise_and(4) > 0 }}"
    • name: “isg_betriebsstatus_NHZ_STUFEN_IN_BETRIEB”
      state: " {{ states(‘sensor.isg_betriebsstatus’)|int|bitwise_and(8) > 0 }}"
    • name: “isg_betriebsstatus_HEIZBETRIEB”
      state: " {{ states(‘sensor.isg_betriebsstatus’)|int|bitwise_and(16) > 0 }}"
    • name: “isg_betriebsstatus_WARMWASSERBETRIEB”
      state: " {{ states(‘sensor.isg_betriebsstatus’)|int|bitwise_and(32) > 0 }}"
    • name: “isg_betriebsstatus_VERDICHTER”
      state: " {{ states(‘sensor.isg_betriebsstatus’)|int|bitwise_and(64) > 0 }}"
    • name: “isg_betriebsstatus_SOMMERBETRIEB”
      state: " {{ states(‘sensor.isg_betriebsstatus’)|int|bitwise_and(128) > 0 }}"
      device_class: “running” `
Hello everyone,
I’m struggeling with my bitcoded value from my LWZ.
In my isg_sensors.yaml I’ve got a sensor representing the systemstatus called “Betriebsstatus”
  - name:                'HEIZUNG-BETRIEBSSTATUS'
    slave:              1
    address:            2000
    input_type:         input
    data_type:          uint16
At present I got the value 17.
In a second file called binary_sensor.yaml I hava got separate sensors to get the different status out of the bitcoded value.
  sensors:
    isg_betriebsstatus_hk1_pumpe:
      friendly_name: "Heizung Schaltprogramm aktiv"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(1) > 0 }}"
    isg_betriebsstatus_hk2_pumpe:
      friendly_name: "Heizung Verdichter"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(2) > 0 }}"
    isg_betriebsstatus_aufheizprogramm:
      friendly_name: "Heizung Heizen"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(4) > 0 }}"
    isg_betriebsstatus_en:
      friendly_name: "Heizung KĂŒhlen"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(8) > 0 }}"
    isg_betriebsstatus_heizbetrieb:
      friendly_name: "Heizung Warmwasserbereitung"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(16) > 0 }}"
    isg_betriebsstatus_waremwasserbetrieb:
      friendly_name: "Heizung Elektr. NE"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(32) > 0 }}"
    isg_betriebsstatus_verdichter:
      friendly_name: "Heizung Service"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(64) > 0 }}"
    isg_betriebsstatus_sommerbetrieb:
      friendly_name: "ISG State Summer Mode active"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(128) > 0 }}"
    isg_betriebsstatus_kuehlbetrieb:
      friendly_name: "ISG State Cooling active"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(256) > 0 }}"
    isg_betriebsstatus_auftauen:
      friendly_name: "ISG State Defrost active"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(512) > 0 }}"
    isg_betriebsstatus_silentmode1_active:
      friendly_name: "ISG State Silentmode1 active"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(1024) > 0 }}"
    isg_betriebsstatus_silentmode2_active:
      friendly_name: "ISG State Silentmode2 active"
      value_template: "{{ states('sensor.HEIZUNG-BETRIEBSSTATUS')|int|bitwise_and(2048) > 0 }}"
My dashboard shows for all binary sensors the vale “not availible”. I can not get it run.
Does anybode have an idea, where to find the mistake or waht to change?
exactly what i was looking for! Thank you very much! :slight_smile:
Hi all,
I installed the Stiebel Eltron ISG extension in my HA instance and nearly everything works like expected.
What is missing is a translation of the bitcoded status, which is shown as the current “Betriebsstatus” (operating mode in english I guess) as just a number.
In my view the status is flipping over the day between several modes:
2 - 3 - 83 - 98 - 595 -
98 - is a defined warm water heating slot at 12PM
2 - seems to be off or just a heating circuit pump is running
3 - is really short, a few seconds only
83 - seems to be the normal heating mode, as the device is consuming a lot of energy during that period
595 - a few minutes long - could be the defreezing mode or something similar
Linking it to a post above the section
might match the status 2 - cause bitwise and for 1 is the decimal number 2, which reflects the case that only one of my heating circuit pumps is running.
Does anyone have a table to translate these modes into a human readable status?
Thanks,
Wolf
