How can I use escape characters while templating?
I read the docs here:
However I need to use a template to send a MQTT payload that has {{ test }} in it. I’m using data_template to build my MQTT payload.
How can I do this?
I’ve tried the template tester in dev tools and cannot figure out how to do it
{{ '{{ test }}' }}
Nice, I didn’t know you could print things within the brackets like that. It works great, thanks. :slight_smile:
I was trying to set up variables like this:
{% set json = {
  "start": "{{",
  "end": "}}"
{{ json.start }} test {{ json.end }}
But {{ '{{ test }}' }} works better and doesn’t need multiple lines also.
Yeah, it’s just a string being output. Also, you can make a macro that does the same thing if you need to use it multiple times inside a template:
{%- macro ret(v) %}
{{- '{{{{ {} }}}}'.format(v) }}
{%- endmacro %}
