How can I use / install the Realtek RTL8821CU wifi USB dongle on Home Assistant OS?
I’ve purchased an Odroid N2+, as recommended on the home assistant website. I’ve decided to also buy the WiFi module from hardkernel, which seemed to be the recommended fit for the odroid N2+. It uses the Realtek RTL8821CU chip. However, this dongle is not recognized by the Home Assistant OS. What I tried :
  • plugging the dongle into an USB port ; 2 events are recorded :
22-04-26 23:56:15 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/bus/usb/001/006 - None
22-04-26 23:56:16 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/bsg/0:0:0:0 - None
  • using the following commands in the CLI on home assistant :
    login
    nmcli radio
    , which informed me that WIFI-HW is ENABLED, WIFI is ENABLED, WWAN-HW is ENABLED, WWAN is ENABLED
    nmcli device wifi rescan
    , which told me the following : Error : No Wi-Fi device found.
    nmcli device wifi
    , which told me nothing.
Does anyone have an idea on how to get this dongle to work ?
Thanks in advance
I’m in the same boat.
It seems to me that the kernel drivers are not installed, so the radio can’t be used. Home Assistant OS is also a super minimal distribution without a package manager (like apt) or a toolchain on it, so we can’t install or compile the kernel module on the device as well.
Therefore I think there are two solutions:
  1. Build your own HomeAssistant OS image with the RTL8821CU driver module included. It seems that some other wifi/bluetooth module drivers are already included so maybe this could be merged upstream at some point.
  2. Switch to Home Assistant Supervised:
    following these instructions. By installing Debian or Ubuntu as a base, it should be relatively straightforward to get the driver via apt. The downside is that now all the hardware configuration and supervisor setup is on you.
I think I’m going to investigate #1 right now, it’s more effort now but with some luck it doesn’t mean maintaining my local OS for the rest of my life :wink:
So the first piece of the puzzle is here:
when the dongle is connected, it first shows up as a CD-ROM with the (windows) driver on it. By running usb_modeswitch -KW -v 0bda -p 1a2b it can be put into operating mode and then immediately starts working as a bluetooth dongle on Home Assitant OS, but WIFI still doesn’t work.
Next clue: Hardkernel have breaktrus rtl8821cu driver in their linux kernel tree. Not sure if they made any changes.
However I downloaded their ubuntu-18.04.4-4.9-minimal-odroid-n2-20200229.img image, and I can’t find the driver in there:
find lib/modules/4.9.213-67/kernel/  |grep rtl
lib/modules/4.9.213-67/kernel/drivers/staging/rtl8712
lib/modules/4.9.213-67/kernel/drivers/staging/rtl8712/r8712u.ko
lib/modules/4.9.213-67/kernel/drivers/bluetooth/btrtl.ko
lib/modules/4.9.213-67/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-rtl28xxu.ko
lib/modules/4.9.213-67/kernel/drivers/media/dvb-frontends/rtl2832_sdr.ko
lib/modules/4.9.213-67/kernel/drivers/media/dvb-frontends/rtl2832.ko
lib/modules/4.9.213-67/kernel/drivers/media/dvb-frontends/rtl2830.ko
lib/modules/4.9.213-67/kernel/drivers/net/wireless/realtek/rtl818x
lib/modules/4.9.213-67/kernel/drivers/net/wireless/realtek/rtl818x/rtl8187
lib/modules/4.9.213-67/kernel/drivers/net/wireless/realtek/rtl818x/rtl8187/rtl8187.ko
lib/modules/4.9.213-67/kernel/drivers/net/wireless/rtl8812au
lib/modules/4.9.213-67/kernel/drivers/net/wireless/rtl8812au/rtl8812au.ko
lib/modules/4.9.213-67/kernel/drivers/net/wireless/rtl8188eu
lib/modules/4.9.213-67/kernel/drivers/net/wireless/rtl8188eu/8188eu.ko
lib/modules/4.9.213-67/kernel/drivers/net/wireless/rtl8192cu
lib/modules/4.9.213-67/kernel/drivers/net/wireless/rtl8192cu/8192cu.ko
lib/modules/4.9.213-67/kernel/drivers/net/usb/rtl8150.ko
EDIT: I managed to build and install the driver in a custom hassos image, a PR can be found here:
There appears to be a bug in the buildroot usb_modeswitch package that prevents it from functioning as expected (it should do the modeswitch automatically). I’ll try to bring that up upstream as well.
I’m trying to use the Odroid 5BK wifi/bluetooth module on a Home Assistant Blue but it seems to be not recognised.
I see this in Supervisor log when I connect the dongle:
In network settings it does not show up as new network adapter.
Can you advise how to get this dongle working on the HA Blue?
I found this description on Hardkernel’s product page:
“Only one minor difference from the previous 5B model is that doesn’t have a CD-ROM mode. So, we can skip the usb-modeswitch tweak.”
Can it be the reason why the 5BK version is not recognised?
