I want to control my IR device with telnet.
I tried to use “telnet” command but “command not found”.
I also tried “Telnet Switch”, but the IR device needs to sleep when command sent, so I have to use telnet command with sleep.
I use ´curl telnet://´ instead of pure telnet in my docker container.
Just I also tried curl command such as: (sleep 1; echo "command"; sleep 1) | curl --raw --connect-timeout 3 telnet://192.0.0.1:51013
(But it is not working yet. I have to adjust bash commands)
