oneiro
April 14, 2023, 10:17am
1
Hello
I refer to Huawie integration issue:
opened 10:44AM - 13 Apr 23 UTC
waiting for feedback
Home Assistant Issue
Hello.
I made integration with inverter via Huawei API and all seems working … fine expect visualisation results and efficiency in percents.
Can you please change efficienty from bar style to normal graphs like current, voltage or Hz? My view is:
![image](https://user-images.githubusercontent.com/50861081/231734203-fcbd0021-3748-4233-8aa6-071d3f51530e.png)
Make zoon in time this looks like that - it is not user friendly to read:
![image](https://user-images.githubusercontent.com/50861081/231734427-ae3be55b-91e5-4e93-8faf-314c2124cf77.png)
My inverter is SUN2000-8KTL-M1
General entitie efficiency in % display as bar-graph, I’d like change it to normal grpahs this min tow axex X na Y where X is time and Y is value in %.
I found that is need add UoM but how to add it in HA?
BR, Krzysiek
tom_l
April 14, 2023, 10:58am
2
You can use customize but the developer should fix it by adding a unit,
