I don’t understand how to get the information from HA to control the esphome relay. Could I get some help on how to use the two different patforms
esphome:
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "7oGzmWzQVXQ8JNNmmgwO1fuT0RLFQL4F/nn0iSr9L6A="
ota:
password: "f4bbe2147ae742b8a98107898bad8ff9"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp-Boiler Fallback Hotspot"
password: "hctNWB6MLhiA"
captive_portal:
binary_sensor:
- platform: homeassistant
entity_id: input_boolean.varaajan_lamporaja_high
on_press:
then:
output:
- platform: gpio
pin:
number: D3
mode: output
interval:
- interval: 25s
then:
- output.turn_on: esp_boiler_Relay3
- delay: 2s
- output.turn_off: esp_boiler_Relay3
