How did custom panel get added as integration…and how do I get rid of it? Noticed it today. Can’t get rid of it in UI, says it was created using configuration.yaml. But it’s not in configuration.yaml. Does anyone have a clue?
I’m curious about this too. It showed up when the 2024.8 update was installed and all integrations now show in the integrations view.
There is a separate section for this in the release notes:
On my system, the yaml code for the custom panel is still available in configuration.yaml.
I read the notes but there is nothing in my configuration.yaml referring to custom panels. I had never heard of them before.
I need help with this as well. This custom panel appeared after deleting a Hacs integration two weeks ago but now I can’t remove this custom panel from the UI.
BUMP BUMP. Can anyone tell us why Custom Panel is now an integration that cannot be removed?
