How did I set Up Outbound TTS Phone Calls in Home Assistant with Asterisk, Fritz!Box & Vodafone
This guide walks through how I set up outbound voice calls from Home Assistant — where HA calls my mobile phone and plays a spoken TTS message. I use a Fritz!Box router with a Vodafone SIP connection, the TECH7Fox Asterisk add-on, and Google Translate TTS with ffmpeg for audio generation.
I also cover every debugging step I went through, so if something breaks for you, you know how to diagnose it.
My Setup
  • Home Assistant OS on Raspberry Pi
  • Vodafone cable connection in Baden-Württemberg, Germany
  • Fritz!Box router with Vodafone SIP connection
  • TECH7Fox Asterisk add-on (Home Assistant add-on store)
  • File Editor add-on (to edit Asterisk config files)
How It Works
HA Automation → script.make_tts_call → Google TTS → ffmpeg → Asterisk → Fritz!Box → Vodafone SIP → Your Phone
  1. An automation triggers script.make_tts_call with a message and phone number
  2. HA generates a TTS audio file via Google Translate (free, no API key)
  3. ffmpeg converts the MP3 to a WAV format Asterisk can play
  4. Asterisk dials the primary number via Fritz!Box
  5. If no answer after 30 seconds, it dials a fallback number
  6. When answered, the voice message plays (repeated twice)
Phase 1 — Fritz!Box: Create an Internal SIP Account
Fritz!Box acts as your SIP proxy — it handles the Vodafone connection and Asterisk registers as an internal phone.
  1. Open your browser → go to fritz.box
  2. Go to Telephony → Telephony Devices → Configure New Device
  3. Select Telephone (with and without answering machine)
  4. Select LAN/WLAN (IP telephone)
  5. Set name: HomeAssistant
  6. Set username HomeAssistant
  7. Set a password (e.g. hapass123) — write this down
  8. Fritz!Box assigns an internal number like **620write this down
  9. Click Apply
Phase 2 — Install Asterisk Add-on
  1. In HA go to Settings → Add-ons → Add-on Store
  2. Click the three dots (top right) → Repositories
  3. Add: https://github.com/TECH7Fox/asterisk-hass-addons
  4. Search AsteriskInstall
  5. Enable Start on boot and Watchdog → click Start
The add-on will create its config directory at:
/addon_configs/3e123456_asterisk/asterisk/custom/
Note: the folder ID (3e123456_asterisk) may differ on your installation. Check /addon_configs/ after first start.
Phase 3 — Configure Asterisk
Asterisk config files go in /addon_configs/3e123456_asterisk/asterisk/custom/. Use the File Editor add-on to create these files.
pjsip.conf
Important: This Asterisk version uses PJSIP, not the older SIP channel. Using SIP/ in dial strings will fail with “No channel type registered for ‘SIP’”.
Replace 620, hapass123, and HomeAssistant with the values from your Fritz!Box setup.
[transport-udp]
type=transport
protocol=udp
bind=0.0.0.0:5060
[fritzbox-auth]
type=auth
auth_type=userpass
username=HomeAssistant
password=hapass123
[fritzbox-aor]
type=aor
contact=sip:192.168.178.1
[fritzbox]
type=endpoint
outbound_auth=fritzbox-auth
aors=fritzbox-aor
from_user=HomeAssistant
from_domain=192.168.178.1
context=from-internal
disallow=all
allow=ulaw
allow=alaw
send_pai=yes
trust_id_outbound=yes
[fritzbox-reg]
type=registration
server_uri=sip:192.168.178.1
client_uri=sip:[email protected]
retry_interval=60
extensions.conf
This handles two scenarios:
  • [outbound] — simple single call with playback
  • [alert-with-fallback] — calls primary number, falls back to secondary if no answer, sets caller name
[outbound]
exten => s,1,Answer()
same => n,Wait(2)
same => n,Playback(/media/ha_alert)
same => n,Hangup()
exten => _+.,1,Answer()
same => n,Set(PRIMARY=${CUT(EXTEN,_,1)})
same => n,Set(SECONDARY=${CUT(EXTEN,_,2)})
same => n,Set(CALLERID(name)=Home Alert)
same => n,Dial(PJSIP/${PRIMARY}@fritzbox,30,A(/media/ha_alert))
same => n,GotoIf($["${DIALSTATUS}" = "ANSWER"]?done)
same => n,Dial(PJSIP/${SECONDARY}@fritzbox,30,A(/media/ha_alert))
same => n(done),Hangup()
Key design decisions:
  • Both numbers are encoded in the extension using _ as separator: Local/+49XXX_+49YYY@alert-with-fallback
  • Answer() at the start stabilizes the LOCAL channel — without it, the channel dies after the first Dial() times out and the fallback never fires
  • A(/media/ha_alert) plays the audio file to the called party immediately when they answer
  • /n flag on the LOCAL channel disables optimization that was killing the channel between retries
  • 30-second ring timeout per number
Restart the Asterisk add-on after creating/modifying these files.
Phase 4 — TTS Audio Generation
Add these shell commands to your configuration.yaml:
shell_command:
generate_tts: "curl -s 'https://translate.google.com/translate_tts?ie=UTF-8&q={{ message | urlencode }}&tl=en&client=tw-ob' -A 'Mozilla/5.0' -o /media/ha_alert.mp3"
convert_tts: "ffmpeg -y -i /media/ha_alert.mp3 -filter_complex 'aevalsrc=0:c=mono:s=8000:d=1[silence];[0:a][silence][0:a]concat=n=3:v=0:a=1[out]' -map '[out]' -ar 8000 -ac 1 -acodec pcm_s16le /media/ha_alert.wav"
  • generate_tts — downloads TTS audio from Google Translate (free, no API key required)
  • convert_tts — converts MP3 to 8kHz mono WAV (required by Asterisk) and repeats the message twice with a 1-second pause between
Note: Do not combine these into one command using && in a YAML > block — the line folding causes the && to be passed incorrectly to the shell.
Restart HA after adding these.
Phase 5 — The Script
Create a reusable script in Settings → Scripts → Add Script → Edit in YAML:
alias: Make TTS Call
fields:
phone:
description: Primary phone number
example: "+4917XXXXXXXX"
fallback_phone:
description: Fallback phone number if primary does not answer
example: "+4917YYYYYYYY"
message:
description: Message to speak
example: "Motion detected at front door"
sequence:
- service: shell_command.generate_tts
message: "{{ message }}"
- service: shell_command.convert_tts
- service: hassio.addon_stdin
addon: 3e123456_asterisk
input: "channel originate Local/{{ phone }}_{{ fallback_phone }}@alert-with-fallback/n application Wait 120"
mode: single
Phase 6 — Using It in Automations
Add this to any automation’s action:
- service: script.make_tts_call
phone: "+4917XXXXXXXX"
fallback_phone: "+4917YYYYYYYY"
message: "Motion detected at the front door"
Or with dynamic AI-generated messages (see bonus section below).
Debugging with Developer Tools
Throughout the setup, I used Developer Tools → Actions to test every step independently. Here is the full debugging sequence in order.
1. Verify the SIP peer connected to Fritz!Box
action: hassio.addon_stdin
input: "pjsip show endpoints"
2. Make a test call using a built-in Asterisk sound
input: "channel originate PJSIP/+4917XXXXXXXX@fritzbox application Playback tt-monkeys"
If your phone rings and plays a monkey sound — Fritz!Box and Asterisk are connected correctly.
3. Verify a dialplan context loaded correctly
input: "dialplan show alert-with-fallback"
4. Reload dialplan without restarting add-on
input: "dialplan reload"
5. Test TTS generation
action: shell_command.generate_tts
message: "Motion detected at front door"
Then check /media/ in File Editor for ha_alert.mp3.
6. Test WAV conversion
action: shell_command.convert_tts
Then check /media/ for ha_alert.wav.
7. Test full call with fallback
input: "channel originate Local/+4917XXXXXXXX_+4917YYYYYYYY@alert-with-fallback/n application Wait 120"
Hope this helps someone avoid the hours of debugging I went through! Feel free to ask questions in the comments.
Hi Sushil,
thanks for the how to.
I have a problem with phase 5.
When I’m trying to save it always tells me YAML Error duplicate mapping key.
Can you please post the code with indentation, looks like the editor stripped it while saving.
looks like all conf examples are stripped.
thx
.g
try this and let me know if it does not work for you.
fields:
  phone:
    example: +4917XXXXXXXX
  fallback_phone:
    example: +4917YYYYYYYY
  message:
    example: Motion detected at front door
sequence:
  - data:
  - action: shell_command.convert_tts
  - data:
      addon: 3e533915_asterisk
      input: >-
mode: single
Many thanks @ayushmaan_jain
I have a Fritz!Box 4050 and with some help from GEMENI it works now.
I had to change the following in the extenstions.conf:
exten => _X._X.,1,Answer()
I had to set the international format to 00 instead of +
And last I had to change the setting in the Fritz!Box about the country-prefix from 'none' to 'without prefix'
Maybe this helps someone other.
Regards Johnny
I have the following problem:
[16:54:22] INFO: Executing command from stdin: asterisk -rx ‘channel originate Local/00xxxxxxxxx79_00xxxxxxxxx09@alert-with-fallback/n application Wait 120’
[Aug 1 16:54:22] NOTICE[1665]: core_local.c:755 local_call: No such extension/context 00xxxxxxxxx79_00xxxxxxxxx09@alert-with-fallback while calling Local channel
Asterisk ending (0).
I also dont see the ‘620’ which I must replace with ‘621’ in the pjsip.conf
Many thanks
