I made a sensor, which contains the path and filename of a photo :
Now I want to display that photo, but this seems not to work…
type: picture
image: '{{ states(''sensor.random_photo'') }}'
Must be something stupid, but…
type: picture
You are missing the fact that most core cards do not support templates.
Create a template image and put that in a picture entity card.
configuration].yaml
template:
- image:
- name: My Picture
url: "{{ states('sensor.random_photo') }}"
Card:
type: picture-entity
show_state: false
show_name: false
camera_view: auto
entity: image.my_picture
I have a separate template.yaml file, how can I put it there ?
I tried this, but get an error :
- trigger:
- platform: time_pattern
seconds: "/10"
- name: random_photo
state: >
{{ state_attr('sensor.photo_album', 'file_list')|random |replace("config/www","local") }}
- image:
- name: My Picture
The schema for the home assistant helper extension needs updating. I get the same warning in VSCode:
Do a config check then restart if it passes.
I did forget one thing though. You need a trigger to update the image. e.g.mine:
- trigger:
minutes: "/30"
- platform: homeassistant
event: start
- platform: event
event_type: event_template_reloaded
image:
- name: Astroweather
url: http://www.7timer.info/bin/astro.php?<redacted>
- name: Cloud Cover +6hrs
url: http://www.skippysky.com.au/Tasmania/cloud_total/tas_006_cct.png
- name: Cloud Cover +12hrs
url: http://www.skippysky.com.au/Tasmania/cloud_total/tas_012_cct.png
- name: Cloud Cover +24hrs
url: http://www.skippysky.com.au/Tasmania/cloud_total/tas_024_cct.png
- name: Cloud Cover +33hrs
url: http://www.skippysky.com.au/Tasmania/cloud_total/tas_033_cct.png
OK, it seems to work (I think) :
But it’s not displayed :
My sensor has the correct value :
Putting that value directly in the card works fine :
What am I missing ?
In Developer Tools → States, what do you see when you click on the “i” button next to the image entity?
And can you share your template config?
Nothing too :
Here are my templates :
- trigger:
event: start
- platform: event
seconds: "/10"
state: >
- trigger:
event: start
- platform: event
- platform: state
entity_id:
- sensor.random_photo
image:
- name: My Picture
What does this return in the template editor:
That’s a path not a url. Not entirely sure if that is supported.
Also do you have either:
default_config:
Or
image:
In your configuration.yaml file?
I have default_config
Changed the sensor and now it is working
state: >
{{ state_attr('sensor.photo_album', 'file_list')|random |replace("/config/www","http://192.168.1.6:8123/local") }}
Thank you Tom !
