I’d like to check if Lux is < 10 when motion is detected.
Preferably in this events: state node.
I can’t find a good way to do this and I would consider this to be quite a basic ask?
Look at the switch node. You would insert it and your test between the state node for the lamp brightness and your dimmer call.
You could also use a Trigger State node and put both conditions (motion and Lux) in that node.
