How do I add a custom mdi icon?
I’m currently putting my solar heating system on my Lovelace dashboard, and all is going well, except I can’t figure out how to use my own custom icon. So far I’ve used the “entity picture” option in https://github.com/custom-cards/button-card and put my png in the WWW folder, and my custom image does show, but being an image I can’t make its colour change based on state, so I need to make it an icon. And I also don’t want to have to create a different png for all the different colours required, that will get out of hand once I start really customising my dashboard.
Here’s the current png showing my solar tube collector, all boring and black and unable to change colour :pensive:
solar
So over to you guys: how do I add my own icon to Home Assistant?
Something to read. :slightly_smiling_face:
Not sure i this works in the latest versions. There was a change about icons a few versions ago.
Jeez that was a rabbit hole! Ended up about 5 layers of links in and crosseyed :joy:
So if I understood it correctly, I need to find a way to convert my PNG into an SVG string somehow and then put that string in a JavaScript file and add it as a module?
That’s correct. I saw a custom card that looked like the Tesla power wall might be what you want.
I have used Inkscape to draw SVG files. With the late HA change to how Icons are loaded into HA, it takes a bit of work to convert/hand-edit the SVG file so that the string being referred to above can be used with the new js loading scheme.
And you can even convert PNG graphics via Path → Trace Bitmap to SVG in Inkscape.
I recommend to Path → Union your icon before saving as Optmized SVG.
