I have:
- Zooz 800 Series Long Range USB Controller
- Schlarge BE469
- HAOS
I did the following:
- Added Z-Wave JS UI via Add-on, added sucessfuly
- Went to UI of Zwave JS - configured the device in the settings section by providing USB device path. Device is configured correctly, here are logs
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-zwave-js-ui: starting
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-zwave-js-ui successfully started
s6-rc: info: service zwave-js-ui: starting
s6-rc: info: service zwave-js-ui successfully started
s6-rc: info: service discovery: starting
[20:39:08] INFO: Starting the Z-Wave JS UI...
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
2024-04-03 20:39:10.045 INFO APP: Version: 9.9.1
2024-04-03 20:39:10.052 INFO APP: Application path:/opt
______ __ __ _ _____ _ _ _____
|___ / \ \ / / | |/ ____| | | | |_ _|
/ /____\ \ /\ / /_ ___ _____ | | (___ | | | | | |
/ /______\ \/ \/ / _' \ \ / / _ \ _ | |\___ \ | | | | | |
/ /__ \ /\ / (_| |\ V / __/ | |__| |____) | | |__| |_| |_
/_____| \/ \/ \__,_| \_/ \___| \____/|_____/ \____/|_____|
2024-04-03 20:39:10.102 WARN STORE: scenes.json not found
2024-04-03 20:39:10.149 INFO APP: Listening on port 44920 protocol HTTP
2024-04-03 20:39:10.181 INFO MQTT: MQTT is disabled
2024-04-03 20:39:10.184 WARN BACKUP: Store backup is disabled
2024-04-03 20:39:10.186 WARN BACKUP: Nvm backup is disabled
2024-04-03 20:39:10.212 INFO Z-WAVE: Connecting to /dev/ttyACM0
[20:39:10] INFO: Starting NGinx...
Logging to file:
/data/store/logs/zwavejs_2024-04-03.log
2024-04-03 20:39:12.333 INFO GATEWAY: Driver is READY
2024-04-03 20:39:12.334 INFO Z-WAVE: Z-Wave driver is ready
2024-04-03 20:39:12.334 INFO Z-WAVE: Controller status: Driver ready
2024-04-03 20:39:12.344 INFO Z-WAVE: Scanning network with homeid: 0xcbfd5300
2024-04-03 20:39:12.347 INFO Z-WAVE: [Node 001] Is alive
2024-04-03 20:39:12.350 INFO Z-WAVE: [Node 001] Value added 1-32-0-currentValue => undefined
2024-04-03 20:39:12.392 INFO Z-WAVE: [Node 001] Ready: Zooz - ZST39 LR (800 Series Long Range USB Controller)
2024-04-03 20:39:12.394 INFO Z-WAVE: Controller status: Scan completed
2024-04-03 20:39:12.394 INFO Z-WAVE: Network scan complete. Found: 1 nodes
2024-04-03 20:39:12.397 INFO Z-WAVE-SERVER: ZwaveJS server listening on 0.0.0.0:3000
2024-04-03 20:39:12.405 INFO Z-WAVE: Z-Wave server started
2024-04-03 20:39:13.356 INFO Z-WAVE-SERVER: DNS Service Discovery enabled
2024-04-03 20:39:13.472 INFO Z-WAVE: Next update scheduled for: Thu Apr 04 2024 00:00:00 GMT-0700 (Pacific Daylight Time)
[20:39:22] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
2024-04-03 20:39:37.743 INFO APP: GET /health/zwave 301 3.801 ms - 191
2024-04-03 20:40:07.803 INFO APP: GET /health/zwave 301 1.045 ms - 191
2024-04-03 20:40:37.855 INFO APP: GET /health/zwave 301 0.540 ms - 191
2024-04-03 20:41:07.898 INFO APP: GET /health/zwave 301 0.662 ms - 191
2024-04-03 20:41:37.935 INFO APP: GET /health/zwave 301 0.802 ms - 191
2024-04-03 20:42:07.967 INFO APP: GET /health/zwave 301 0.531 ms - 191
2024-04-03 20:42:38.000 INFO APP: GET /health/zwave 301 0.493 ms - 191
2024-04-03 20:43:08.038 INFO APP: GET /health/zwave 301 0.719 ms - 191
2024-04-03 20:43:38.073 INFO APP: GET /health/zwave 301 0.794 ms - 191
2024-04-03 20:43:45.426 INFO Z-WAVE-SERVER: Starting logging event forwarder at verbose level
2024-04-03 20:43:50.996 INFO Z-WAVE-SERVER: Stopping logging event forwarder
2024-04-03 20:43:57.041 INFO Z-WAVE: Controller status: Secure inclusion started
2024-04-03 20:44:08.111 INFO APP: GET /health/zwave 301 0.518 ms - 191
2024-04-03 20:44:38.152 INFO APP: GET /health/zwave 301 0.836 ms - 191
2024-04-03 20:44:41.670 INFO Z-WAVE: Controller status: Inclusion stopped
2024-04-03 20:44:48.966 INFO Z-WAVE-SERVER: Starting logging event forwarder at verbose level
2024-04-03 20:44:55.996 INFO Z-WAVE-SERVER: Stopping logging event forwarder
2024-04-03 20:45:08.186 INFO APP: GET /health/zwave 301 0.566 ms - 191
And a screenshot
Then I went to Zwave JS UI → settings, generated S2 Unauthenticated, S2 Authenticated, S2 Access Control, S0 Legacy codes. Saved, rebooted the system. Seems all good.
- Then I went to Devices and Services → add integration. I unchecked Use the Z-Wave JS Supervisor add-on, put ws://a0d7b954-zwavejs2mqtt:3000 as server URL. It added sucessfuly
- I went to the lock, did factory reset.
In HA I click to Add device from the screen above, it starts scannig.
Go to the lock, hit Schlarge button, the deadbolt extends, I enter programming code, green led starts flashing, I press 0 and after several seconds get red checkmark that lock is not enrolled.
I tried at least 10 times. Same outcome.
The lock is about 4 ft away from the HA box. Batteries are fresh - reading of voltage is 5.8V.
What I am doing wrong? Do I need to correct anything to sucessfuly enroll the lock.
This controller and lock are only two Z-wave devices in the house/setup.
