Hello Home Assistant community, I started my transition from SmartThings to Home Assistant a couple of years back but have been forced to finally move some of my most critical automations over when SmartThings killed their Groovy APIs at the start of this year. For the most part, the transition has been relatively straightforward but I am facing one major challenge - how do I automate my Keen smart vents to work in tandem with my Ecobee Thermostat and keep the temperature around my house relatively even. I looked for existing blueprints that could adjust the vents in each room but wasn’t able to find any so I instead tried to create my own automation and got struck 10 seconds in. I want to build an automation that worked as follows…
When my thermostat starts heating or cooling OR the temperature in the room changes DO the following:
IF heating, set the vent in the room as follows:
Temp in room is less than thermostat setting - 1F → 100%
Temp in room is between thermostat setting - 1F and thermostat setting + 1F → 50%
Temp in room is is greater than thermostat setting + 1F → 10%
IF cooling, set the vent in the room as follows:
Temp in room is greater than thermostat setting + 1F → 100%
Temp in room is between thermostat setting + 1F and thermostat setting - 1F → 50%
Temp in room is is greater than thermostat setting - 1F → 10%
However, I didn’t see any option to trigger an automation based on Ecobee thermostat state changing:
What am I missing? Is this a limitation of Home Assistant’s automations, the Ecobee integration, or the underlying Ecobee API?
P.S. Triggering automations based on my Ecobee Thermostat state changing is possible in SmartThings so I was very surprised to find that functionality missing in Home Assistant:
I think I finally figure it out. I was able to use the state trigger with the fan attribute of my Ecobee thermostat. It’s still a work in progress but this is what my automation looks like now:
