How do I change the temperature to F from C?
I just purchased a Gosund ST1 temperature & humidity sensor. I was able to get it to work but I am unable to change the temperature mode.
If you can’t change it on the device you can always make a template that displays the temperature in F
Similar to this
{% set t = states(‘sensor.nanopi_cpu_temperature’) | float(0) %}
{{(((t)*9/5)+32) | round(1)}}
