How do I configure MyEnergi integration downloaded using HACS
I would like to integrate my MyEnergi Hub and Eddi into HA. I found there is a third party integration, and followed the instructions to install it via HACS.
I installed HACS successfully, and restarted the server.
I then added the MyEnergi integration, and restarted the server again.
But I can’t for the life of me find out how to configure the integration - there should be a place to put my login or API key in, but I can’t find it.
Help?
after you download it via HACS you need to go to the HA integrations page and add it from there.
I think I did that - see screenshot:
What do I click on to add my login/key details?
It’s OK, I figured it out - having added it using HACS, you then have to add it again in Settings/Integrations.
