I’ve seen references to putting max_gps_accuracy into the configuration.yaml file, but it seems like this may be one of those things that has moved out of the configuration.yaml file? I’m pretty new to Home Assistant, and it is very confusing reading old articles on how to achieve something that don’t match up with the current Home Assistant UI and configuration files.
Can you please be very specific on what I need to put where in the most recent version? I tried just adding a device_tracker section to my configuration.yaml and it seemed to override the existing OwnTracks stuff and broke everything.
On a semi-related note - how do I remove old and unused OwnTracks Entities? When I try to “Remove Selected” it says “You can only remove 0 of the selected 1 entities. Entities can only be removed when the integration is no longer providing the entities. Sometimes you have to restart Home Assistant before you can remove the entities of a removed integration. Are you sure you want to remove the removable entities?”
