How do I configure the Hue-Service-Advanced integration (hacs)?
Hello together,
I want to enable/disable the motion sensor with this integration.
I have installed the Hue-Service-Advanced integration in hacs but I just don’t understand how to configure it. I’ve read something in the thread with 1200 entries, followed some dead links, tried to make sense out of the example on github.
What files do I need to adjust? And maybe someone has achieved this and can provide some example code?
Thank you,
Bernd
If you open an issue on GitHub the developer is sure to see it and respind.
Anyone solve this? I’m also looking for an concrete example on how to configure the Hue Service Advance integration in Home Assistant. Right now it’s only include some instruction that I’m as a newbe cannot follow.
How do you
Service set_motion_sensor
Set config for binary sensor or sensor.
in home assistant. Where are you doing that, how? What are the fields, where to put those? Does anyone have a concrete example?
