How do i convert a global 1D-Array of integers into a composed string
i tried with c_str - i tried with to_string - and several other ideas, but all failed. It should be trivial for C++ experts but i am just a c++ beginner !
Background: i do some calculations inside LAMBDA and want to see the intermediate results of the array without extracting every single value by templating…
Can you show us your yaml / lambda so far?
Hi, in the meantime i asked ChatGPT and got somenthing, but Synthax did no really fit, but gave good hints. After some back and forth, the following code worked and gave exactly the string i needed:
# Globals zur übergreifenden Verwendung in allen LAMBDAs
globals:
    # interne variablen  ->
  - id: my_global_array
    type: int[5]
    initial_value: '{1, 2, 13, 4, 15}'
text_sensor:
    lambda: |-
      std::string result;
      int i ;
      for ( i = 0; i < 5; ++i)
        result += to_string(id(my_global_array)[i]);
        if (i < 4 ) {
        result += ","; // Add a comma between numbers
      return result;
what did not worked as suggested by ChatGPT was the lenght of the array:
like
id(my_global_array).size()
which gave a compilation error…
Any ideas ??
