What’s the value of your sensor in developer tools? It may be something like “unknown” or “unavailable”, in which case that’s the issue to investigate.
will give you a figure in watts. If the sensor isn’t working for any reason and its state can’t be converted, the int filter will use 0 as a default.
I don’t think that’s your issue though. If an integration is expecting to see something that looks like an integer in a sensor but it isn’t seeing that, a template isn’t going to help you. Give more details.
The integration is foxess_em. The bug has been reported by someone else, and I have also added that I have the same issue. The first person said that they had fixed it using a template.
in my home assistant log it says:
error (Main thread) [custom_components.foxess_em.battery.battery_controller] ValueError(“invalid literal for int() with base 10: ‘94.0’”)
I can tell from the value (94.0) that this is the battery State of Charge, which is another sensor that works just fine elsewhere.
