Hi, apricate if someone can help me with one of my scripts here. I have a script the “warms the floor” which gets triggered when the heating is on and the floor temp drops below a set point (under floor heating)
The idea of the script is to raise the temperature of the floor to 25c, by increasing the setpoint of the thermostat by 1 degree. Once the floor reaches 25c i set the thermostat temperature back to what ever it was before, unless the set temp has already been changed. This could be by me manually or when when the schedule changes.
The bit that isn’t working for me is the condition that checks if the set temp has changed, i can not seem to use the variable correctly.
I’m assuming the new_set_temp variable should display its value here…
Here’s my script…
alias: Warm Floor
variables:
old_set_temp: '{{ states.climate.living_room.attributes.temperature | float }}'
new_set_temp: >-
{{ ((states.climate.living_room.attributes.current_temperature) + 1) |
round(0,"ceil") }}
sequence:
- service: climate.set_temperature
entity_id: climate.living_room
data_template:
temperature: '{{ new_set_temp }}'
- wait_for_trigger:
- platform: numeric_state
above: '25'
attribute: floor_temperature
for:
hours: 0
minutes: 5
seconds: 0
timeout: '01:00:00'
- condition: state
attribute: temperature
state: '{{ new_set_temp }}'
temperature: '{{ old_set_temp }}'
mode: single
Any help would be greatly apricated, or advice on a better way to deal with detecting if the set temperature had changed since being set by HA.
Cheers
