How do I create reliable working timers
I use the generic thermostat to control my central heating.
One of the functions of the central heating is to heat my floor and for this I have designed an automation that uses climate.turn_on/off function, which control the gas burner and turns the burner on for 20 minutes and turns it off after 20 minutes, until the set room temperature is reached.
Often this works fine, but there are times when it doesn’t work. E.g. the burner does not switch off after 20 minutes and stays on or does not switch on and everything cools down.
As a timer I use the delay function, but these timers are reset if e.g. Home Assistant restarts, etc.
My question is, is there a (more) reliable solution so that the initiated delays keep their value.
Thank you.
alias: CV Heater Control
description: ''
  - platform: state
    entity_id: climate.kamerthermostaat
    attribute: hvac_action
    to: heating
    for: '00:20:00'
  - platform: state
    entity_id: binary_sensor.tuindeur_contact
    to: 'off'
    for: '00:10:00'
  - platform: state
    to: 'on'
    for: '00:00:45'
  - platform: homeassistant
    event: start
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - door_open
              - heating
        sequence:
          - service: climate.turn_off
    default: []
  - choose:
      - conditions:
        sequence:
          - delay: '00:20:00'
    default: []
  - choose:
      - conditions:
            id:
              - door_closed
              - heating
        sequence:
          - service: climate.turn_on
    default: []
mode: single
None of the time-based concepts in Home Assistant can survive a restart or Reload Automations (delay, for, wait_template, wait_for_trigger, repeat, etc) and timers don’t survive a restart or Reload Timers.
To make active, or paused, timers survive a restart, I created this system to restore them:
Otherwise, there’s a programming technique where instead of using a delay you compute the time when the automation should be triggered. For example, if you want to delay for 20 minutes, before executing the next step, you add 20 minutes to the current time and assign it to an input_datetime. That input_datetime is used by the automation in a Time Trigger.
When the automation’s Time Trigger fires, the automation uses a choose to direct execution to the next step.
A Time Trigger is unaffected by restart/reload because unless it happens at the precise time when the Time Trigger occurs (and there are ways to mitigate that as well).
The technique I described makes the automation more robust but it also makes it more complex because it requires an input_datetime (to hold the future time), a Time Trigger, and the use of choose to determine which trigger fired in order to direct execution flow to the proper step.
FWIW, several of my automations use the described programming technique and a few others (that employ timers) use the timer-restoration system. I can freely restart/reload the system without concern that it will derail an (important) automation.
Thank you for your reply.
I have read the link you provide and understand what you are saying.
I’ve read almost all your replies in other threads, and these replies inspire my to change or to create my automations.
You are talking about using input_datetime, and I think I like that solution, but till now I have never used this feature before.
Can you please give me an example how to start?
Thank you for your time to help me.
I think I’m on the right way.
For now, to test, I’ve created 3 automations which work nearly well.
There is still one thing to solve.
{{ now().strftime("%s")|int + 1200 }} create a waiting time of 1h20 instead of 20m.
Somehow it adds 1 hour extra.
configuration:
input_datetime:
  only_time:
    has_time: true
automation:
  - platform: state
    to: heating
condition: []
  - service: input_datetime.set_datetime
      entity_id: input_datetime.only_time
      timestamp: '{{ now().strftime("%s")|int + 1200 }}'
# Turns off burner at the time specified.
  - platform: time
    at: input_datetime.only_time
condition: []
# Turns on burner at the time specified.
  - platform: time
condition: []
What you created there has a few syntax errors but the most crucial problem is that it’s not a functional replacement for a State Trigger’s for option.
Given this:
  - platform: state
    to: heating
    for: '00:20:00'
it means to trigger when the value of hvac_action changes to heating and remains that way for at least 20 minutes. That means it must be heating for a continuous 20 minutes before it triggers.
What you created behaves differently; it simply sets a future trigger time. That behaves like a delay and nothing else. It doesn’t confirm that the value of hvac_action actually remained heating throughout the 20 minutes.
The for option behaves like a timer. The instant that the value of hvac_action changes to heating, the 20-minute countdown begins. When it expires, the trigger fires. If the value of hvac_action changes from heating to something else like idle during the 20-minute countdown, the countdown timer is reset. It starts again when the value of hvac_action changes to heating.
I think this automation catch it all.
What do you think?
alias: CV-4
description: ''
  - platform: state
    to: heating
  - platform: time
    at: input_datetime.turn_off
  - platform: time
    at: input_datetime.turn_on
    event: start
condition: []
  - choose:
      - conditions:
          - condition: template
            value_template: '{{ trigger.id == "start" }}'
        sequence:
              entity_id: input_datetime.turn_off
              timestamp: '{{ now().strftime("%s")|int + 1200 - 3600 }}'
    default: []
  - choose:
      - conditions:
            value_template: >-
              {{ trigger.id == "off" and state_attr("climate.kamerthermostaat",
              "hvac_action") == "heating" }}
        sequence:
              entity_id: input_datetime.turn_on
    default: []
  - choose:
      - conditions:
            value_template: >-
              {{ trigger.id == "on" or (trigger.id == "off" and
              state_attr("climate.kamerthermostaat", "hvac_action") != "idle")
        sequence:
          - service: climate.turn_{{ trigger.id }}
    default: []
mode: single
Like I explained in my previous post, that doesn’t behave like a State Trigger’s for option does. However, if you don’t mind that it doesn’t, then use that.
