How do I display the state of an entity in an entities list?
Hi, complete noob here just getting started with HA. I am trying to create a card to show general information about my set up such as the state of my lights and curtains in rows. For example, i want a card that shows if my Living Room light is on or off, instead of a switch to toggle.
I’ve tried using the entities card, and for entities like persons it shows fine but how do i display the state of the entities on the right column instead of a toggle switch? i tried using type:attribute but it shows a ‘-’ instead. Answer is probably super obvious but i’m lost, can some kind soul point me in the right direction?
here’s my code -
type: entities
title: At a Glance
entities:
  - entity: person.me
  - type: attribute
    entity: light.bathroom_bathroom_319
    attribute: brightness
  - type: attribute
    entity: cover.living_living_curtain_341
    attribute: state
show_header_toggle: false
state_color: true
Thanks!
What you’re asking for isn’t easy. By default, the entities card will try to display each entity as the type that they are. I.e. your switch will appear as a switch.
You have plenty of options to do this, but they all require some extra configuration or custom lovelace cards.
The easiest way, without anything custom, would be to make a template binary sensor.
template:
- binary_sensor:
  - name: Living Room Curtain State
    state: >
      {{ is_state('cover.living_living_curtain_341', 'open') }}
    device_class: opening
then display that in your entities card
type: entities
title: At a Glance
entities:
  - entity: person.me
  - type: attribute
  - entity: binary_sensor.living_room_curtain_state
state_color: true
Hi Petro, thanks for the prompt reply.
Ah ok… I thought it would be doable since the Glance cards actually show exactly what i want. Is it then possible to show Glance cards in a vertical format?
thanks again!
