Hi. I am super new to home assistant. I hope you can help me with an automation that I want to do.
I have two fence doors named fence_A and fence_B. I want the switch named light.kitchen to turn on if either fence_A or fence_B is open. If both fence_A and fence_B are closed, then I want light.kitchen to turn off.
For the open you can just set the trigger to be as described above with “or” logic. For the closed though you will need to use “or” logic for the trigger but have a condition for “and”.
What are the actual door entity_id’s? I.e., sensor.fence_A, binary_sensor.fence_A, cover.fence_A, switch.fence_A, …? For this example I’ll just assume they’re binary_sensor’s (where open corresponds to a state of ‘on’, and closed corresponds to a state of ‘off’.) Adjust accordingly if your sensors are something else.
You can do this in one automation using a state trigger, and service_template in the action part:
- alias: Change kitchen light per fence doors
platform: state
entity_id: binary_sensor.fence_A, binary_sensor.fence_B
service_template: >
# If either fence door is open, turn on light. Else turn it off.
{% if is_state('binary_sensor.fence_A', 'on') or
is_state('binary_sensor.fence_B', 'on') %}
light.turn_on
{% else %}
light.turn_off
{% endif %}
entity_id: light.kitchen
So, whenever either door changes the action will run. If either door is open, the light is turned on. Otherwise (i.e., both doors closed) the light will be turned off.
service_template: >
{% if is_state('binary_sensor.fence_A', 'on') and
light.turn_on
{% else %}
light.turn_off
{% endif %}
can ‘and’ be used like added above. 2. Would this act such that if fence_a and fence_b are ‘on’ the light would turn on, but if only one is on or both off the light would turn off?
