How do I permanently, automatically edit values that need to be set via sysctl
? Usually, you put them in a file into /etc/sysctl.d
This directory is part of /
which is mounted read-only, and it’s SquashFS, so I don’t think I can just remount it as RW.
Background for completeness:
I have a Wi-Fi USB Dongle running hostapd using GitHub - mattlongman/Hassio-Access-Point: Hass.io addon to let you create a WiFi access point, perfect for using WiFi devices on off-grid installations. for my IOT-Specific network.
The onboard wi-fi is a client on my main house wi-fi.
I need the IOT devices to be accessible on the main wi-fi. I figured out how to do it using proxy_arp
and WiFi promiscuous mode.
I can turn on promiscuous mode from the hostapd script inside docker, so that’s not an issue.
I can’t turn on net.ipv4.conf.wlan0.proxy_arp
from the container, that has to be turned on from the host. I’ve been testing it using SSH to host via 22222, but it’s all ready to do, and I can’t figure out how to make the changes permanent.
Thanks, y’all.
