How do i fix this sql error
I installed mariaDB and get this error constantly
How can i fix this?
Here is what did in my config.yaml
Recorder:
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:50
Integration: Recorder ([documentation](https://www.home-assistant.io/integrations/recorder), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+recorder%22))
First occurred: 4:12:00 (1 occurrences)
Last logged: 4:12:00
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: DELETE FROM events WHERE events.event_id IN (?, ?, ?,
But you don’t use it …
correct, the error is from sqllite, not mariadb🤔
