How do i fix Unable to install package pybluez==0.22: error:
i just upgraded to the new home assistant and i get this blue tooth error how do i fix it?
Logger: homeassistant.util.package
Source: util/package.py:107
First occurred: 6:50:36 PM (9 occurrences)
Last logged: 7:00:30 PM
Unable to install package pybluez==0.22: error: subprocess-exited-with-error × python setup.py bdist_wheel did not run successfully. │ exit code: 1 ╰─> [19 lines of output] running bdist_wheel running build running build_py creating build creating build/lib.linux-x86_64-cpython-311 creating build/lib.linux-x86_64-cpython-311/bluetooth copying bluetooth/__init__.py -> build/lib.linux-x86_64-cpython-311/bluetooth copying bluetooth/widcomm.py -> build/lib.linux-x86_64-cpython-311/bluetooth copying bluetooth/osx.py -> build/lib.linux-x86_64-cpython-311/bluetooth copying bluetooth/msbt.py -> build/lib.linux-x86_64-cpython-311/bluetooth copying bluetooth/btcommon.py -> build/lib.linux-x86_64-cpython-311/bluetooth copying bluetooth/bluez.py -> build/lib.linux-x86_64-cpython-311/bluetooth copying bluetooth/ble.py -> build/lib.linux-x86_64-cpython-311/bluetooth running build_ext building 'bluetooth._bluetooth' extension creating build/temp.linux-x86_64-cpython-311 creating build/temp.linux-x86_64-cpython-311/bluez gcc -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I./port3 -I/usr/local/include/python3.11 -c bluez/btmodule.c -o build/temp.linux-x86_64-cpython-311/bluez/btmodule.o error: command 'gcc' failed: No such file or directory [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Failed building wheel for pybluez ERROR: Could not build wheels for pybluez, which is required to install pyproject.toml-based projects
Remove the bluetooth_tracker: entry in your configuration.yaml
It’s deprecated and no longer works.
oh ok does that mean the bluetooth in the raspberry pi is no longer functional and i need a esp32 beside it… or is there a plugin?
@Neil_Brownlee where are you getting that the bluetooth_tracker is deprecated? Nothing in the latest release change log or the bluetooth_tracker integration docs mentions it. There are a couple new issues on Home Assistant Core’s Github for the problem after today’s 2023.06.0 release.
pybluez doesn’t work with the latest Python version.
Fine.
And is there an alternative for the bluetooth tracker, that works???
SOLUTION FOR DOCKER USERS ONLY:
Step 1:
For Docker Compose users:
Add the following to the Home Assistant container section of your docker-compose.yaml file
command: /bin/sh -c "apk add gcc musl-dev bluez-dev ; /init"
For Unraid users:
Edit your Home Assistant container and add the following to “Post Arguments” (switch the view to Advanced to see this field)
For Portainer users:
Add the following to the “Command” field in the “Advanced container settings” section of your Home Assistant container
Step 2:
Download the bluetooth_tracker integration files from the home-assistant GitHub. You can do this by going to https://download-directory.github.io and entering the following into the box:
https://github.com/home-assistant/core/tree/dev/homeassistant/components/bluetooth_tracker
Step 3:
Unzip the download, change the directory name to “bluetooth_tracker” and open it.
Step 4:
Replace everything in the manifest.json file with this:
  "domain": "bluetooth_tracker",
  "name": "Bluetooth Tracker",
  "codeowners": [],
  "documentation": "https://www.home-assistant.io/integrations/bluetooth_tracker",
  "iot_class": "local_polling",
  "loggers": ["bluetooth", "bt_proximity"],
  "requirements": ["bt-proximity==0.2.1", "git+https://github.com/pybluez/pybluez.git#pybluez==0.30"],
  "version": "1.0.0"
Step 5:
Add the directory to your custom_components directory
Step 6:
Restart Home Assistant and hopefully it works!
EDIT: Removed a step as it’s no longed needed.
EDIT 2: Added Portainer users section to Step 1
I can confirm, this solution works.
Thank You so much
Is this a solution or with the next release of 2023.06.1 you will have to do it again and again?
impossible to make this fix for me :
~ pip install git+https://github.com/pybluez/pybluez.git#egg=pybluez
Collecting pybluez
  Cloning https://github.com/pybluez/pybluez.git to /tmp/pip-install-m15j_iel/pybluez_4d22b1c29d6d4fcfbb9ceb9b062d3595
  Running command git clone --filter=blob:none --quiet https://github.com/pybluez/pybluez.git /tmp/pip-install-m15j_iel/pybluez_4d22b1c29d6d4fcfbb9ceb9b062d3595
  Resolved https://github.com/pybluez/pybluez.git to commit 4d46ce14d9e888e3b0c65d5d3ba2a703f8e5e861
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
  Preparing metadata (pyproject.toml) ... done
Building wheels for collected packages: pybluez
  Building wheel for pybluez (pyproject.toml) ... error
  × Building wheel for pybluez (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [22 lines of output]
      running bdist_wheel
      running build
      running build_py
      creating build
      creating build/lib.linux-aarch64-cpython-311
      creating build/lib.linux-aarch64-cpython-311/bluetooth
      copying bluetooth/macos.py -> build/lib.linux-aarch64-cpython-311/bluetooth
      copying bluetooth/__init__.py -> build/lib.linux-aarch64-cpython-311/bluetooth
      copying bluetooth/ble.py -> build/lib.linux-aarch64-cpython-311/bluetooth
      copying bluetooth/bluez.py -> build/lib.linux-aarch64-cpython-311/bluetooth
      copying bluetooth/msbt.py -> build/lib.linux-aarch64-cpython-311/bluetooth
      copying bluetooth/btcommon.py -> build/lib.linux-aarch64-cpython-311/bluetooth
      running build_ext
      creating build/temp.linux-aarch64-cpython-311
      creating build/temp.linux-aarch64-cpython-311/bluez
      gcc -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/usr/include/python3.11 -c bluez/btmodule.c -o build/temp.linux-aarch64-cpython-311/bluez/btmodule.o
      bluez/btmodule.c:20:10: fatal error: Python.h: No such file or directory
         20 | #include "Python.h"
      compilation terminated.
      error: command '/usr/bin/gcc' failed with exit code 1
      [end of output]
Failed to build pybluez
and in log :
2023-06-08 16:20:12.944 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package PyBluez==0.30: ERROR: Could not find a version that satisfies the requirement PyBluez==0.30 (from versions: 0.20, 0.21, 0.22, 0.23)
ERROR: No matching distribution found for PyBluez==0.30
2023-06-08 16:20:12.949 ERROR (MainThread) [homeassistant.config] Platform error: device_tracker - Requirements for bluetooth_tracker not found: ['PyBluez==0.30'].
perhaps it could be fix in the next core version ?
You miss the line:
“apk add gcc musl-dev bluez-dev”
inside the container of homeassistant. Follow precisely all commands.
I’ve just followed the instructions and it works.
No it’s was okay with this command
Collecting pybluez
but i use HASSIO ,…
With Hassio I don’t know if it is possible to fix, do you have access at a command like: docker ps
yes thanks i have sucessfully install pybluez and tracker work fine !
I think so too
how to install this solution on a raspberry?
No command pip
So, with 2023.6.1 i had to do step 1 again (apk add and pip install)
Not nice
Maybe you need to enter the homeassistant container :
sudo docker exec -it homeassistant /bin/bash
@acid115 @miky_italy
I’ve worked out a way for the changes to not be undone with HA docker image updates! Please have a look at my original reply again.
NOTE: In addition to the obvious change to step 1, make sure you don’t miss the change made to the manifest.json file of the custom_component, specifically the requirements line.
I get the same error. Are you running HA OS?
