# Establish Substitutions
substitutions:
device_name: sprinkler
friendly_name: "Sprinkler"
device_platform: ESP32
device_board: esp32dev
device_ip:X.X.X.X
sensor_update_frequency: 1s
packages:
wifi: !include common/device_wifi.yaml
device_base: !include common/device_base_ESP32.yaml
home_assistant_api: !include common/device_api.yaml
sensor_wifi_ip_address: !include common/sensor_wifi_ip_address.yaml
# Enable logging
logger:
##### I/O expander hub definition
mcp23017:
- id: 'mcp23017_hub'
address: 0x20
#nodemcu devkit v4.0
i2c:
sda: 21
scl: 22
scan: True
frequency: 100kHz
# 10x4 LCD config
display:
- platform: lcd_pcf8574
dimensions: 20x4
address: 0x27
update_interval: 1s
lambda: |-
switch (id(esp32_sprinkler_ctrlr).active_valve().value_or(-1)) {
case 0: //valve0, zone1, internal valve numbers not zone_valve_swX numbers
it.printf(0, 0, "Zone1: %s", id(zone_valve_sw1).state ? "ON" : "OFF");
if (id(zone_valve_sw1).state) {
it.printf(0, 1, "Mins: %2d of", id(esp32_sprinkler_ctrlr).time_remaining().value_or(0) / 60 );
it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(0) / 60);
} else {
it.printf(0, 1, "Mins Set %2d ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(0) / 60);
break;
case 1: //valve1, zone2,
it.printf(0, 0, "Zone2: %s", id(zone_valve_sw2).state ? "ON" : "OFF");
if (id(zone_valve_sw2).state) {
it.printf(0, 1, "Mins: %2d of", id(esp32_sprinkler_ctrlr).time_remaining().value_or(0) / 60);
it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(1) / 60);
} else {
it.printf(0, 1, "Mins Set %2d ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(1) / 60);
break;
case 2: //valve2, zone3,
it.printf(0, 0, "Zone3: %s", id(zone_valve_sw3).state ? "ON" : "OFF");
if (id(zone_valve_sw3).state) {
it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(2) / 60);
} else {
it.printf(0, 1, "Mins Set %2d ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(2) / 60);
break;
case 3: //valve3, zone4
it.printf(0, 0, "Zone4: %s", id(zone_valve_sw4).state ? "ON" : "OFF");
if (id(zone_valve_sw4).state) {
it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(3) / 60);
} else {
it.printf(0, 1, "Mins Set %2d ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(3) / 60);
break;
case 4: //valve4, zone5
it.printf(0, 0, "Zone5: %s", id(zone_valve_sw5).state ? "ON" : "OFF");
if (id(zone_valve_sw5).state) {
it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(4) / 60);
} else {
it.printf(0, 1, "Mins Set %2d ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(4) / 60);
break;
case 5: //valve5, zone6
it.printf(0, 0, "Zone6: %s", id(zone_valve_sw6).state ? "ON" : "OFF");
if (id(zone_valve_sw6).state) {
it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(5) / 60);
} else {
it.printf(0, 1, "Mins Set %2d ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(5) / 60);
break;
case -1:
it.printf(0, 1, "Status: %s", id(esp32_sprinkler_ctrlr_status).state.c_str());
it.strftime(12, 0,"%H:%M:%S", id(homeassistant_time).now());
break;
default:
break;
output:
- platform: ledc
pin: GPIO14
light:
- platform: monochromatic
output: sprinkler_backlight
name: "LCD Display Sprinkler Backlight"
restore_mode: ALWAYS_ON
# Enable Home Assistant APIs
api:
reboot_timeout: 0s
services:
- service: set_multiplier
variables:
multiplier: float
then:
- sprinkler.set_multiplier:
multiplier: !lambda 'return multiplier;'
- service: start_full_cycle
then:
- sprinkler.start_full_cycle: esp32_sprinkler_ctrlr
- service: start_single_valve
variables:
valve: int
then:
- sprinkler.start_single_valve:
valve_number: !lambda 'return valve;'
- service: next_valve
then:
- sprinkler.next_valve: esp32_sprinkler_ctrlr
- service: previous_valve
then:
- sprinkler.previous_valve: esp32_sprinkler_ctrlr
- service: shutdown
then:
- sprinkler.shutdown: esp32_sprinkler_ctrlr
- service: pause
then:
- sprinkler.pause: esp32_sprinkler_ctrlr
- service: resume
then:
- sprinkler.resume: esp32_sprinkler_ctrlr
- service: resume_or_full_cycle
then:
- sprinkler.resume_or_start_full_cycle: esp32_sprinkler_ctrlr
- service: repeat_2
then:
- sprinkler.set_repeat:
repeat: 2 # would run three cycles
- service: repeat_3
then:
repeat: 3 # would run three cycles
# Main sprinkler code
sprinkler:
- id: esp32_sprinkler_ctrlr
main_switch: "Master Run/Stop"
auto_advance_switch: "Zones Auto Advance"
reverse_switch: "Zones Reverse"
valve_open_delay: 2s
valves:
- valve_switch: "Zone 1"
enable_switch: "Zone 1 Enable"
run_duration: 900s
valve_switch_id: zone_valve_sw1
- valve_switch: "Zone 2"
enable_switch: "Zone 2 Enable"
run_duration: 900s
valve_switch_id: zone_valve_sw2
- valve_switch: "Zone 3"
enable_switch: "Zone 3 Enable"
run_duration: 900s
valve_switch_id: zone_valve_sw3
- valve_switch: "Zone 4"
enable_switch: "Zone 4 Enable"
run_duration: 900s
valve_switch_id: zone_valve_sw4
- valve_switch: "Zone 5"
enable_switch: "Zone 5 Enable"
run_duration: 900s
valve_switch_id: zone_valve_sw5
- valve_switch: "Zone 6"
enable_switch: "Zone 6 Enable"
run_duration: 900s
valve_switch_id: zone_valve_sw6
# Valve control outputs config via I/O expander
switch:
####### CONTROL SWITCH
name: "Sprinkler Controller Run"
optimistic: true
on_turn_on:
- text_sensor.template.publish:
state: "Running"
- switch.turn_off: esp32_sprinkler_ctrlr_pause
- switch.turn_off: esp32_sprinkler_ctrlr_stop
name: "Sprinkler Controller Stop"
optimistic: true
on_turn_on:
state: "Stopped"
- switch.turn_off: esp32_sprinkler_ctrlr_run
name: "Sprinkler Controller Pause"
optimistic: true
turn_on_action:
- delay: 500ms
- lambda: |-
if(id(esp32_sprinkler_ctrlr_status).state != "Running")
id(esp32_sprinkler_ctrlr_pause).turn_off();
- lambda: |-
if(id(esp32_sprinkler_ctrlr_status).state == "Running")
id(esp32_sprinkler_ctrlr_status).publish_state("Paused");
id(esp32_sprinkler_ctrlr).pause();
on_turn_off:
lambda: |-
if(id(esp32_sprinkler_ctrlr_status).state == "Paused")
id(esp32_sprinkler_ctrlr_status).publish_state("Running");
id(esp32_sprinkler_ctrlr).resume();
name: "Sprinkler Controller Resume"
optimistic: true
####### I/0 SWITCH
- platform: gpio
name: "MCP23017 Pin B2"
pin:
mcp23xxx: mcp23017_hub
# Use pin B2
number: 10
# One of INPUT or OUTPUT
mode:
output: true
inverted: true
internal: true
- platform: gpio
name: "MCP23017 Pin B3"
pin:
# Use pin B3
number: 11
mode:
output: true
inverted: true
internal: true
- platform: gpio
name: "MCP23017 Pin B4"
pin:
# Use pin B4
number: 12
mode:
output: true
inverted: true
internal: true
- platform: gpio
name: "MCP23017 Pin B5"
pin:
# Use pin B5
number: 13
mode:
output: true
inverted: true
internal: true
- platform: gpio
name: "MCP23017 Pin B6"
pin:
# Use pin B6
number: 14
mode:
output: true
inverted: true
internal: true
- platform: gpio
name: "MCP23017 Pin B7"
pin:
# Use pin B7
number: 15
mode:
output: true
inverted: true
internal: true
#- platform: template #this switch doesn't work properly. Can pause via HA frontend, but will not resume... Via Services does work...
# id: pause_switch
# name: "Pause Irrigation Switch"
# turn_on_action:
# then:
# - sprinkler.pause: esp32_sprinkler_ctrlr
# turn_off_action:
# then:
# - sprinkler.resume: esp32_sprinkler_ctrlr
number:
# Configuration to set multiplier via number
name: "Run Duration Multiplier"
min_value: 1.0
max_value: 3.0
step: 0.1
mode: box
lambda: "return id(esp32_sprinkler_ctrlr).multiplier();"
set_action:
multiplier: !lambda 'return x;'
# Configure repeat
name: "Sprinkler Repeat Cycles"
min_value: 0
max_value: 300
step: 1
mode: box
lambda: "return id(esp32_sprinkler_ctrlr).repeat();"
set_action:
repeat: !lambda 'return x;'
# Configuration to set valve run duration via number
name: "Zone 1 Duration"
icon: mdi:timer
unit_of_measurement: Min
min_value: 1
max_value: 120
step: 1.0
update_interval: $sensor_update_frequency
mode: box
lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(0) / 60;"
set_action:
- sprinkler.set_valve_run_duration:
valve_number: 0
run_duration: !lambda "return x * 60;"
name: "Zone 2 Duration"
icon: mdi:timer
min_value: 1
max_value: 120
step: 1.0
mode: box
lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(1) / 60;"
set_action:
valve_number: 1
name: "Zone 3 Duration"
icon: mdi:timer
min_value: 1
max_value: 120
step: 1.0
mode: box
lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(2) / 60;"
set_action:
valve_number: 2
name: "Zone 4 Duration"
icon: mdi:timer
min_value: 1
max_value: 120
step: 1.0
mode: box
lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(3) / 60;"
set_action:
valve_number: 3
name: "Zone 5 Duration"
icon: mdi:timer
min_value: 1
max_value: 120
step: 1.0
mode: box
lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(4) / 60;"
set_action:
valve_number: 4
name: "Zone 6 Duration"
icon: mdi:timer
min_value: 1
max_value: 120
step: 1.0
mode: box
lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(5) / 60;"
set_action:
valve_number: 5
### SENSORS
name: "Cycle Total Time Sensor"
icon: mdi:progress-clock
unit_of_measurement: 'Min'
accuracy_decimals: 0
lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(0)/60 + id(esp32_sprinkler_ctrlr).valve_run_duration(1)/60;"
#lambda: |-
# {% set ns = namespace(states=[]) %}
# {% for s in states.sensor %}
# {% if s.object_id.startswith('valve_run_') and s.object_id.endswith('_duration') %}
# {% set ns.states = ns.states + [ s.state | float ] %}
# {% endif %}
# {% endfor %}
# {{ ns.states | sum | round(2) }}
name: "Zone Time Remaining Sensor"
lambda: |-
if(id(esp32_sprinkler_ctrlr_status).state != "Paused")
return id(esp32_sprinkler_ctrlr).time_remaining().value_or(0) / 60;
else
return {};
# lambda: |-
# int seconds = round(id(esp32_sprinkler_ctrlr).time_remaining().value_or(0));
# int days = seconds / (24 * 3600);
# seconds = seconds % (24 * 3600);
# int hours = seconds / 3600;
# seconds = seconds % 3600;
# int minutes = seconds / 60;
# seconds = seconds % 60;
# return {
# ((days ? String(days) + "d " : "") +
# (hours ? String(hours) + "h " : "") +
# (minutes ? String(minutes) + "m " : "") +
# (String(seconds) + "s")
# ).c_str()};
# # Expose Progress Percent as a sensor.
name: "Zone Progress"
unit_of_measurement: '%'
icon: "mdi:progress-clock"
lambda: |-
int valve_progress_percent = round(((id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(id(esp32_sprinkler_ctrlr).active_valve().value_or(0)) - id(esp32_sprinkler_ctrlr).time_remaining().value_or(0)) * 100 / id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(id(esp32_sprinkler_ctrlr).active_valve().value_or(0))));
return valve_progress_percent;
# std::string progress_percent_as_string = esphome::to_string(progress_percent);
name: "Zone Active Sensor"
unit_of_measurement: ''
#Valves are numbered from 0-7 internally which is an issue when displaying !
lambda: |-
if(id(esp32_sprinkler_ctrlr_status).state == "Stopped")
return id(esp32_sprinkler_ctrlr).active_valve().value_or(NAN);
else
return id(esp32_sprinkler_ctrlr).active_valve().value_or(NAN) + 1;
- platform: homeassistant
entity_id: timer.sprinklercountdown
internal: false
text_sensor:
### Input to managet the display backlight
entity_id: input_number.sprinklerbacklightlevel
internal: true
on_value:
then:
- output.turn_on: sprinkler_backlight
- output.set_level:
level: !lambda |-
return atoi(id(display_sprinkler_backlight).state.c_str()) / 100.0;
# Time source config
time:
timezone: Europe/Rome
