My Fritz switches have temperature sensors in them.
I would like to display the temperature (in appdaemon dashboard)
How do I do that?
Provided this shows up in HA, use the attributes:
{{state_attr("switch.fritz_box_name","temperature")}}
EDIT: Ignore me, looks like you wanted AppDaemon… No idea then I don’t use it. sorry
Just add the attribute to the name of the entity. If your switch is named switch.my_switch
, your widget would look like:
fritz_temp:
widget_type: sensor
entity: switch.my_switch.temperature
Also, better to ask in the HADashboard category since this category is about writing appdaemon apps in python for use with or without HADashboard.
Ahh ok, thankyou will do, and btw. it worked perfectly
