fribse
(Kenneths Teknik)
August 9, 2020, 5:05am
1
While I’m waiting for my two relay esp01s boards, I’ve started doing the small code for it.
The ‘double relay’ boards uses a template switch like this:
switch:
name: '${device_name} Mode change'
turn_on_action:
- uart.write: [0xA0, 0x02, 0x01, 0xA3]
turn_off_action:
- uart.write: [0xA0, 0x02, 0x00, 0xA2]
I tried using this to get it show up as a light:
output:
type: binary
turn_on_action:
turn_off_action:
light:
- platform: binary
output: light_relay
But I can’t do a turn_on_action or turn_off_action apparently in output?
tom_l
August 9, 2020, 6:05am
2
Yeah it looks like you only have on_write_action
for a template output. https://esphome.io/components/output/template.html#output-template-on-write-action
So you will need condition(s) to determine which action to take.
fribse
(Kenneths Teknik)
August 9, 2020, 7:00am
3
I see, I’ve changed it to this, I hope it works, but I’ll have to see when the boards arrive, at least it’s accepted by the compiler now
substitutions:
device_name: raclette
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifissid
password: !secret wifipw
ap:
ssid: "${device_name} Hotspot"
password: !secret appw
# Enable Home Assistant API
api:
ota:
password: !secret otapw
time:
- platform: homeassistant
# Enable logging
logger:
baud_rate: 0 #need this to free up UART pins
uart:
baud_rate: 115200 # speed to STC15L101EW
tx_pin: GPIO1
rx_pin: GPIO3
web_server:
port: 80
auth:
username: !secret webuser
password: !secret webpw
# Text Sensor with general information
text_sensor:
- platform: version
name: '${device_name} ESPHome Version'
- platform: wifi_info
ip_address:
ssid:
binary_sensor:
- platform: gpio
internal: true
pin:
number: GPIO2
mode: INPUT_PULLUP
inverted: true
on_press:
- switch.toggle: relay
- platform: wifi_signal
name: '${device_name} wifi signal'
update_interval: 60s
accuracy_decimals: 0
- platform: uptime
unit_of_measurement: days
update_interval: 300s
accuracy_decimals: 1
filters:
- multiply: 0.000011574
script:
then:
- delay: 120min # timer length
- switch.turn_off: relay
switch:
turn_on_action:
- uart.write: [0xA0, 0x01, 0x01, 0xA2]
- script.execute: countdown
- light.turn_on: relay2
turn_off_action:
- uart.write: [0xA0, 0x01, 0x00, 0xA1]
- script.stop: countdown
- light.turn_off: relay2
optimistic: true
output:
type: binary
write_action:
- if:
condition:
light.is_on: relay2
then:
else:
light:
- platform: binary
output: light_relay
tom_l
August 9, 2020, 7:08am
4
That looks like it should work.
