I added a few of these thermostats, and everything seems to be working fine, but I can’t seem to figure out how to add the humidity reading into home assistant. It doesn’t seem to show up anywhere. Does anyone know what I need to do in order to get that working?
Unfortunately, it didn’t create that. I read a couple posts on other sites and it looks like this might be a very slight difference between the Iris version and the regular CT101. It apparently sends the humidity information in a slightly different way, and open-zwave doesn’t like it.
I’m not 100% sure that is what is happening, but I’m definitely not seeing the humidity sensor.
I know this an older thread, but this turned out to be a bug I guess. It was recently fixed in OpenZWave: https://github.com/OpenZWave/open-zwave/issues/1179
Awesome. Any idea as to when this fix will be pushed to home assistant?
It looks like if you’re not using Hass.io there’s a way to update OpenZWave. I couldn’t find out if this was possible for Hass.io or when we could expect an update.
Seems like this is included in 0.82. I’m seeing humidity now.
