Bschjoett
(Benny Schjoett)
November 12, 2021, 4:40pm
1
I have make a sensor where I use the value from my time helper and subtract 15 min.
In my helper the time selected is 05:30
My sensor show 5:30:00 without the leading zero.
How do I solve this ?
sensors:
frost_check:
friendly_name: "Frosttid"
value_template: "{{ strptime(states('input_datetime.alarmtid'), '%H:%M:%S') - strptime('15', '%M') }}"
123
(Taras)
November 12, 2021, 5:00pm
2
This should do the trick:
sensors:
frost_check:
value_template: "{{ (state_attr('input_datetime.alarmtid', 'timestamp') - 900) | timestamp_custom('%H:%M:%S', false) }}"
Screenshot of Template Editor:
Bschjoett
(Benny Schjoett)
November 12, 2021, 9:21pm
4
Thank you for help it was the solution.
Hey!
Guys trying to add leading zero into my uptime sensor in minutes field, but I think I do something wrong and leading zero is not showing, what I need to do in my case for minutes like 01-09?
Here is my sensor:
- name: input_meter_uptime_short
state: >
{% set uptime = states('sensor.corridor_input_electricity_meter_l3') | int(0) %}
{% set minutes = ((uptime % 3600) / 60) | int(0) %}
{% set hours = ((uptime % 86400) / 3600) | int(0) %}
{% set days = (uptime / 86400) | int(0) %}
{% if days > 0 %}{{ days }}d {% endif %}{% if hours > 0 %}{{ hours }}:{% endif %}{% if minutes > 0 and uptime > 60 %}{{ minutes }}{% elif minutes > 0 and uptime < 60 %}{{ minutes | format(morph=['minute','minutes','minutes'], as_text=false) }}{% else %}<1 min.{% endif %}
attributes:
days: "{{ (states('sensor.corridor_input_electricity_meter_l3') | int(0) / 86400) | int(0) }}"
hours: "{{ ((states('sensor.corridor_input_electricity_meter_l3') | int(0) % 86400) / 3600) | int(0) }}"
minutes: "{{ ((states('sensor.corridor_input_electricity_meter_l3') | int(0) % 3600) / 60) | int(0) }}"
raw: "{{ states('sensor.corridor_input_electricity_meter_l3') | int(0) }}"
icon: mdi:clock-fast
