I want to use the total daily consumption in other locations and wondering how i can easily obtain this value?
I don’t think you can easily, it’s a real shame to be honest.
I think the data is using the statistics and stored in the DB, so I guess at present it would involve some sort on DB query and that’s well over my level of knowledge.
I get round this by using the same sensor I use for energy and creating a utility sensor that in effect creates the same data but mine is updated constantly as opposed to the energy being once an hour I believe.
by utility sensor you mean a template? If so mind sharing so I can get an idea. Thanks
Sorry I meant utility meter (not sensor)
Thanks this works well for my situation.
Ok so this worked fine in 2021.12 version but when i recently upgraded to 2022.2 version something is not right. The sum is much lower then it should be. Anyone else seeing this?
