I am struggling to get Zigbee2MQTT working. Logs say the selected USB port can’t be found. I have hassos installed on a dedicated Intel NUC. I run ha hardware info on the Terminal add-on but the results scroll straight through and I can’t see most of it.
Any ideas folks?
In the GUI go to Supervisor → System → Click 3 dots under Host → Hardware
Of course - thank you! It’s one of the things about trying to start in HA - there is just so much of it ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
Glad you sorted it. Please mark the above as the solution, prevents others thinking you still need an answer ![:blush: :blush:](https://community.home-assistant.io/images/emoji/twitter/blush.png?v=9)
