I have a H801 LED controller with ESPHome and a button attached. Pressing the button, turns the light on/off, holding it dims the light - I need an additional button at a place where physical wiring is impossible - and it needs to work without direct connection to HA (hence api disabled). I have made a configuration that works to turn the light on/off, but I can not figure out how to recreate the dimming while holding the button (both code pieces below). I guess I need some sort of while loop that increments a number from 0 to 255 (brightness), before publishing the MQTT topic - but I can not figure it out. Some advise would be appreciated. It works on the H801 because I can use the relative_brightness function there - but that’s not an option on the remote ESPHome device.
Here’s the configuration for the H801 LED controller with the physical button attached:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
use_address: 192.168.2.108
networks:
- ssid: "SEL_Wifi"
password: "xxx"
- ssid: "Boatnet"
password: "xxx"
manual_ip:
static_ip: 192.168.2.108
gateway: 192.168.2.1
subnet: 255.255.255.0
dns1: 192.168.2.1
ap:
ssid: "Esp28 Fallback Hotspot"
password: "XX"
captive_portal:
# Enable logging
logger:
# Enable MQTT
mqtt:
broker: xxx
username: xxx
password: xxx
port: xxx
# Enable Home Assistant API
#api:
ota:
- platform: wifi_signal
name: "WiFi Signal ESP28 h801"
update_interval: 60s
#RGBWarm
output:
- platform: esp8266_pwm
pin: 12
frequency: 1000 Hz
pin: 13
frequency: 1000 Hz
pin: 15
frequency: 1000 Hz
pin: 14
frequency: 1000 Hz
pin: 16
frequency: 1000 Hz
light:
- platform: rgb
red: pwm_r
green: pwm_g
blue: pwm_b
#white: pwm_w
- platform: cwww
#red: pwm_r
#green: pwm_g
#blue: pwm_b
cold_white: pwm_cw
warm_white: pwm_w
cold_white_color_temperature: 153 mireds
warm_white_color_temperature: 500 mireds
binary_sensor:
- platform: gpio
pin: GPIO03
on_click:
then:
- if:
condition:
light.is_off: h801_ww
then:
light.turn_on:
brightness: 1.0
else:
- light.turn_off: h801_ww
- light.turn_off: h801_rgb
on_press:
then:
- if:
condition:
then:
- delay: 0.5s
- while:
condition:
binary_sensor.is_on: light_0_touch
then:
- light.dim_relative:
relative_brightness: 5%
transition_length: 0.1s
- delay: 0.1s
else:
- delay: 0.5s
- while:
condition:
and:
- binary_sensor.is_on: light_0_touch
- light.is_on: h801_ww
then:
relative_brightness: -5%
- delay: 0.1s
Heres the code on the remote ESPHome, it currently works fine for on/off functionality, but this is where I need some way of increasing the brightness while holding the button.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
use_address: 192.168.2.109
networks:
- ssid: "Boatnet"
password: "xxx"
manual_ip:
static_ip: 192.168.2.109
dns1: 192.168.2.1
- ssid: "SEL_Wifi"
password: "xxx"
ap:
ssid: "Esp41 Fallback Hotspot"
password: "xxx"
captive_portal:
# Enable logging
logger:
# Define virtual sensor to store state of light
text_sensor:
name: "ESP28 light state"
internal: true
# Enable MQTT
mqtt:
broker: xxx
username: xxx
password: xxx
port: xxx
on_json_message:
topic: esp28/light/h801_white/state
then:
- logger.log: "JSON payload received"
- text_sensor.template.publish:
state: !lambda 'return x["state"];'
#api:
ota:
name: "WiFi Signal ESP41"
binary_sensor:
- platform: gpio
pin:
number: D2
mode: INPUT_PULLUP
on_press:
then:
- logger.log: "Press registered"
- if:
condition:
text_sensor.state:
state: 'OFF'
then:
- logger.log: "Publishing ON command"
- mqtt.publish_json:
topic: esp28/light/h801_white/command
payload: |-
root["state"] = "ON";
root["brightness"] = "255";
root["color_temp"] = "500";
- if:
condition:
text_sensor.state:
state: 'ON'
then:
- logger.log: "Publishing OFF command"
payload: |-
root["state"] = "OFF";
